I just wanted to share the fruits of some weekend hacking
>>> MONOCHRON PEW-PEW-PEW video <<<
Some background: this is a port of the code from my homemade retro game watch. The code was already cross-platform (it worked on the watch with an 8051, and under osx using ASCII graphics), but there's some weirdness with the AVR's memory that I need to account for. As you can see, there are still bugs!
Original project (which has been neglected since I joined a startup, so I thought I'd put the code to good use on the monochron):
Game watch video
Watch circuit board (much smaller than the monochron!)
- ericgus
Re: MONOCHRON PEW-PEW-PEW
I was wondering the other day if that could be done on the MONOCHRON .. it would make a great mode for just showing the time.
- dataman
Share your code and I'll help you port it to Pew3Chron!
Take a look at our work at http://github.com/BANNED/MultiChron
Basically, you'd add a new module, anin_pew3.c
You'd need to code init, display, and step
It's pretty easy.
Take a look at anim_ts or anim_int
-Dataman
It's pretty easy.
-Dataman
I based it off the latest version of the ratt code, so it has the same basic modules. Now, if I can only get it to fit in negative 12K of code
It still has some very basic work to go, which I'll be getting... the original display was 96x64x4 bit and I use anti-aliased sprites -- it should be easy to make it 128x64, but I'm not sure what to do with the sprites yet -- aim for software dithering, or reduce the size to 1/4. I also have pre-shifted sprites (2 copies of each one), which are useless now and need to be trashed.
I'm not sure of the code size yet... that'll be interesting
- ericgus
"That page doesn't exist!"dataman wrote:Share your code and I'll help you port it to Pew3Chron!
I looked around and found something that looks similar at http://github.com/BANNED/monochron
Here's an initial release!
Notes:
- doesn't keep time ... it keeps score instead. The goal is to make the score follow the time; if the score it too low the AI should become better (or get a bonus alien); if it's too high it should get worse.
- I detect player collisions with rocks, but I don't do anything about it (except flash the screen).
- AI might not be working great since I ported it (a bug here wouldn't show up easily)
- 3 rocks only at start. We can go higher; what do you think?
- Based on adafruit-monochron-e6e4061 (~sept 9 2010)
- monochrom.hex (included so you don't need to compile it from scratch) is about 26kB
- all fixed point. And not just integers, either. It has 1/2 pixel resolution for most sprites. Angles are in fixed point, too. Atan2 function provided. Yeah, I am a masochist that way.
- Things I dropped from the watch OLED implementation: anti-aliased sprites (can someone hack some grayscale in to this display?), pre-computed shifted sprites (not needed)
- The sprites are implemented for my OLED display (4 bits/pixel, horizontal orientation); they haven't been re-implemented in a way that suits the LCD display (1 but/pixel, vertical orientation). There's code to do the translation on-the-fly & it's horribly inefficient. But frame rate seems fine!
Creative commons license by-nc-sa.
Notes:
- caitsith2
You might want to post a link or attach a file, because how are we supposed to try the initial release if it is not provided in some way?
Good idea Sorry about that... it takes a few more steps here than what I'm used to with gmail
>>> <<<[/b]
>>> <<<[/b]
- dataman
Ok, BANNED is a serious code masochist.
He's busy on another project right now.
When he come up for air, we'll have to see if we can jam code into MultiChron.
Sorry about the bad url, I was jamming kinda fast.
Glad you found our repository.
Yes, floating point is very very costly in tiny CPUs.
If you can do it int, it's always faster.
We converted pong fron FP to int.
Uses approximates now.
Works very well.
Works very well.
I'm excited about multichron... I'll download it tonight! I was looking forward to getting rid of the float stuff, too .,. darn, it'll be harder for me to find more optimizations ... it'll be fun to see what you guys did!
my original pong watch fit in to a processor with only 2KB!
