Hello! I made a silly mistake while putting the clock together. As you can see on the images I soldered the tube holder the wrong way around. And I had to use jumper wires to bring the clock to life. My solder pump can't really desolder the pin headers (or maybe I am doing it the wrong way). Is it possible to order just a spare tube/holder/header?
Any help is appreciated..
Cheers from snowcovered Switzerland!
-andreas
[ice tube Clock] solder problem
- adafruit_support_bill
Re: [ice tube Clock] solder problem
De-soldering anything with that many pins is difficult. One approach is to remove the plastic bridge between the header pins and de-solder them one at a time.
- acahen
Would that be the only reasonable solution? I'll give it a try..
-andreas
Update: Since there is a 10% discount and some spares inside the store, I've ordered a few things more.. That will teach me a lesson
Thanks anyways for helping me out!
-andreas
you can get just a replacement tube set as well, in the shop.
