ice tube problem max circuit
Tick Tock Clock Kits
Postby lavodent » Mon Mar 07, 2011 12:49 am
Hello
I am writing about the kit ICE CUBE
at the entrance of 7805 I have a 9-volt outlet and I have 5 volts or without the tube without Max 6921 I have the 56 volts the diode once I deliver the MAX in 6921 support the voltage at the diode drops to 13 volts and the tube does not light course could you please inform me about this problem I added the welds are very good I used to do electronics it does there is no wiring problems thank you
lavodent
Re: ice tube problem max circuit
Postby adafruit_support_bill » Mon Mar 07, 2011 6:09 am
When did you buy the kit? Can you read the part number on q3?
Postby lavodent » Mon Mar 07, 2011 10:31 am
hello
I buy the kit at home complete with the transparent box and the transformer so the transistor Q3 is a 2907 it was with the other components thank you for your reply.
lavodent
Postby adafruit_support_bill » Mon Mar 07, 2011 10:49 am
This part has been replaced with a P-channel MOSFET in recent versions of the kit. You can contact support@adafruit.com and ask for a new Ice Tube MOSFET. Please reference this thread and your order number in the message.
Postby lavodent » Mon Mar 07, 2011 11:01 am
After checking I realized I had to order the kit from FLORIS.CC in Holland when placing my order with you it was out of stock, what reference you use for the transistor Q3 component? thank you again, you have version 1.1 on your kit and it is possible to buy just please the microprocessor? thank you again
lavodent
Postby adafruit_support_bill » Mon Mar 07, 2011 12:07 pm
The kits currently ship with a ZVP3306 or equivalent. These are not expensive (less than $1 US) You can probably source one from a local supplier.
Postby lavodent » Mon Mar 07, 2011 2:22 pm
thank you for the reply
Could you please what is the difference from version v1 and v1.1?
thank you
lavodent
Postby lavodent » Mon Mar 07, 2011 2:30 pm
Please
Do you think that I just replace the transistor to troubleshoot the kit? or should it also change the regulator and the boost circuit? if so could you tell me the rates for you to order ZVP3306, STP16NF06 STP16NF06 gold, Vishay
IRFD110PBF with shipping costs for France ATmega168V-10PU with version v 1.1 thank you again I can pay via paypal if you want
lavodent
Postby adafruit » Mon Mar 07, 2011 3:22 pm
please email support@adafruit with a link to this thread, we will mail you out a new ice tube MOSFET transistor
Postby lavodent » Fri Mar 11, 2011 1:24 pm
Hi
Tank You
lavodent
Postby lavodent » Mon Mar 14, 2011 11:11 am
Hello
I just got the transistor, really thank you very much I do the replacement and it should work, I'll let you know thank you again
Jean
lavodent
Return to Clocks
Users browsing this forum: No registered users and 3 guests
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
