ICE TUBE:low voltage w boost controller chip
Tick Tock Clock Kits
Re: ICE TUBE:low voltage w boost controller chip
Postby mattkpetersen » Wed Nov 23, 2011 10:09 am
The tube does light, but very briefly. Maybe a second or more, and then it flickers out.
EDIT, Sorry, scratch that. When I short the second and third pins on Q3, the tube briefly lights. It does not light when I short the first and third pins. Where the first pin is the pin adjacent to the edge of the board.
mattkpetersen
Postby adafruit » Fri Nov 25, 2011 6:38 pm
hmm i think we should just try a new kit - email support@adafruit with a link to this post and receive a new ice tube clock kit! :)
Postby mattkpetersen » Fri Nov 25, 2011 11:01 pm
I'll do so. Thanks for your help.
mattkpetersen
Postby Th0mw4lker » Mon Jan 16, 2012 9:06 pm
Hi there,
working on my own Ice Tube kit here and had a similiar issue - no display on power up after sucessful power supply tests. Shorted pins 1 to 3 on q3 as suggested in this post and the display lit weakly but seemed correct (blinking default time). Also able to cycle menus. Q3 is installed corrrectly per the silk screen - could it be blown?
Thom
Th0mw4lker
Postby adafruit_support_bill » Tue Jan 17, 2012 6:09 am
Thom -
Let's start by getting the 4-digit number from the small tube-board. Also, photos of the front & back of the board. In particular the area around the battery sense circuit (R1, R2, C10) and the tube heater circuit (Q3, R3)
Postby Th0mw4lker » Tue Jan 17, 2012 10:28 am
Board Number is 4111
Photos attached
Please note that I completed the project after shorting Q3 (and eventually replacing Q3 with a jumper wire) so I could program and play with the clock (I was bored). The tube displays the correct time, date, and menus - it's just a bit dim. I removed the VFD and checked the voltage on the cathodes of D3 and D5 - right around 56 vdc. The clock "works" just not sure why it's so dim with Q3 removed.
Thom
Th0mw4lker
Postby adafruit_support_bill » Tue Jan 17, 2012 2:30 pm
Q3 is there to turn off the display when the power goes away so it won't drain the backup battery. The symptom you see is often caused by a problem in the battery sense circuit. With the clock on, what do you measure on pin 13 of the microprocessor?
As for the dim display. It does default to a fairly low setting at initial power up. Are you able to alter the brightness from the menu?
Postby Th0mw4lker » Tue Jan 17, 2012 7:41 pm
Yeah - Actually it's quite bright now (didn't try earlier - duh). So Q3 is removed during my tweaking - when I replace it I go back to getting no display. I guess Q3 is shot?
Th0mw4lker
Postby adafruit_support_bill » Tue Jan 17, 2012 8:34 pm
With the clock on, what do you measure on pin 13 of the microprocessor? It could be a problem in the battery sense part of the circuit.
Postby Th0mw4lker » Mon Jan 23, 2012 7:28 pm
Sorry for the delay - work interferes with my life! Clock on, pin 13 is 1.25v
Th0mw4lker
Postby adafruit_support_bill » Mon Jan 23, 2012 7:47 pm
That is above the battery sense threshold (~1.1v), so the processor should be sending power to the VFD via Q3. What voltage do you measure at the gate (center pin) of Q3? It should be pulled low to turn on.
Postby Th0mw4lker » Wed Jan 25, 2012 6:13 pm
I'm getting .32v on the center pin of Q3
Th0mw4lker
Postby Th0mw4lker » Fri Jan 27, 2012 4:06 pm
Nothing -
Th0mw4lker
PreviousNext
Return to Clocks
Users browsing this forum: No registered users and 1 guest
New Products [103]
LEDs[109]
Cables[61]
