My Doctor Who MonoChron Clock
Tick Tock Clock Kits
Postby DanSlage » Fri Feb 03, 2012 1:19 pm
I am working on a Doctor Who inspired clock for the MonoChron. A video can be seen here. http://youtu.be/DHecR3Matss
The TARTIS travels through an wiggly wormhole. Pressing a button or switch (except "Menu") will cause the TARTIS to dematerialize and rematerialize a moment later in a random spot. My daughter plans on using this as her primary alarm clock once I figure out how to replace the alarm siren with the Doctor Who theme song.
I had to rewrite the wormhole code a few times to get it fast enough render correctly. The GLCD.h drawing routines are way too slow instead the wormhole uses glcdDataWrite()s directly to draw everything.
To speed things up I also EXTERMINATEd all division and modulus operations. For example to separate the hour into a high digit and low digit:
Traditional
high_digit = hour/10;
low_digit = hour%10;
I found this to be much faster
high_digit = 0;
low_digit = hour;
while (low_digit >= 10) {  // Count tens
  high_digit++;
  low_digit -= 10;
When you have as much motion as this clock does every clock cycle counts.
DanSlage
Re: My Doctor Who MonoChron Clock
Postby odometer » Sat Feb 04, 2012 4:12 pm
What datatype is "hour"?
This is good up to 99:
high_digit = 0;
low_digit = something;
if (low_digit >= 60) {high_digit += 6; low_digit -= 60;}
if (low_digit >= 30) {high_digit += 3; low_digit -= 30;}
if (low_digit >= 20) {high_digit += 2; low_digit -= 20;}
if (low_digit >= 10) {high_digit += 1; low_digit -= 10;}
odometer
Postby DanSlage » Sat Feb 04, 2012 5:11 pm
Nice Odometer! The datatype is uint8_t but never goes larger than 59 in my program. My gut tells me your code would be faster than mine. I wonder if anyone has ever done any speed trials.
DanSlage
Postby Nicodemus_NJ » Wed May 23, 2012 11:20 am
I hate to be "that guy" but... It's TARDIS! (Time and Relative Dimension in Space)
Nicodemus_NJ
Postby kscharf » Wed May 23, 2012 12:29 pm
DanSlage wrote:I am working on a Doctor Who inspired clock for the MonoChron. A video can be seen here. http://youtu.be/DHecR3Matss
Sounds like you need to interface a wave shield to the clock some how.
kscharf
Postby JakeS » Wed May 23, 2012 4:41 pm
Hi-
Saw your project featured in the Adafruit blog- nice!
We did a Dr. Who song through a piezo speaker an on Arduino. I used an existing program for the piezo frequencies and sound generation, which I have forgotten and can't attribute, sorry! We only figured out the melody and the timing.
const int  b=     4056;    // 261 Hz
const int  c=     3830;    // 261 Hz
const int  d=     3400;    // 294 Hz
const int  e=     3038;    // 329 Hz
const int  f=     2864;    // 349 Hz
const int  g=     2550;    // 392 Hz
const int  a=     2272;    // 440 Hz
const int  B=     2028;    // 493 Hz
const int  C=     1912;    // 523 Hz
const int  D=     1700;    // 523 Hz
const int  E=     1508;    // 523 Hz
const int  F=     1432;    // 523 Hz
const int  G=     1278;    // 523 Hz
const int  A=     1136;    // 523 Hz
// Define a special note, 'R', to represent a rest
const int  R=     0;
int speakerOut = 13;
int melody[] = { b,  C,  B,  D,  a,  B,  B, g,  d,  b,  d, c, b,R } ;
int beats[]  = { 8,  8, 48,  8,  8, 64,  8, 8,  8,  8, 16, 16,16,96 } ;
int MAX_COUNT = 14; // Melody length, for looping.
// Set overall tempo
long tempo = 10000;
// Set length of pause between notes
int pause = 1000;
int rest_count = 100; //<-BLETCHEROUS HACK; See NOTES
for(int js=0; js<20; js++) {
   for (int i=0; i<MAX_COUNT; i++) {
    tone_ = melody[i];
    beat = 4*beats[i];
    duration = beat * tempo; // Set up timing
    playTone();
    // A pause between notes...
    delayMicroseconds(pause);
void playTone() {
  long elapsed_time = 0;
  if (tone_ > 0) { // if this isn't a Rest beat, while the tone has
    //  played less long than 'duration', pulse speaker HIGH and LOW
    while (elapsed_time < duration) {
      digitalWrite(speakerOut,HIGH);
      delayMicroseconds(tone_ / 2);
      // DOWN
      digitalWrite(speakerOut, LOW);
      // Keep track of how long we pulsed
      elapsed_time += (tone_);
  else { // Rest beat; loop times delay
    for (int j = 0; j < rest_count; j++) { // See NOTE on rest_count
      delayMicroseconds(duration);
JakeS
Postby adafruit » Thu May 24, 2012 5:31 pm
I second using the piezo to just play the theme, it sounds good on Tesla coils so a piezo should be fine too :)
Return to Clocks
Users browsing this forum: No registered users and 2 guests
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
