- monochron.jpg (135.68 KiB) Viewed 793 times
Monochron display problem
- tcharron
My monochron developed a problem after months (years?) of operation. The bottom rows are showing garbage. I'm pretty adept at soldering, but figured that maybe I had made a mistake so I took it apart looking for a problem. After checking everything I can't figure the problem. Image is attached...does anyone have a guess?
- adafruit_support_bill
Re: Monochron display problem
Does pressing on the bezel affect the display at all?
- tcharron
I will double check tonight. I did try to slightly push in to/pull out of the header strip slightly and removed/reinserted when I had it apart to see if it helped and it didn't.adafruit_support wrote:Does pressing on the bezel affect the display at all?
- tcharron
Pressure on the bezel has no effect on the display.
Sometimes the conductive elastomer strips that connect the lcd controller to the lcd itself lose contact. But that usually takes out whole rows or columns. It looks like you have just a few dead pixels.
I have heard that you can sometimes fix stuck pixels on LCD TV's, but I don't know if the same techniques would apply to these displays.
