Cant get pmb 648 to parse?
Tick Tock Clock Kits
Postby thinwing » Mon Apr 23, 2012 3:29 pm
Ordered basic gps module from adafruit to add to icetube clock.After trying seperate sketches including one from parallax,I cannot seem to read usable data on serial monitor.Wired as shown using three wires,and all sketches compilevand load ok on arduino uno...connected to clock,no time correction I can detect...help..kpc
thinwing
Re: Cant get pmb 648 to parse?
Postby adafruit_support_bill » Mon Apr 23, 2012 4:20 pm
Are you trying to connect to the Arduino or the clock?
Postby thinwing » Mon Apr 23, 2012 4:42 pm
I have done both.Using the red ,black,and yellow wires as shown in both tutorials.With the clock ,it acts like it is waiting for info it never recieves.When connected to arduino ,and test schetch is run,serial monitor reveals gibberish...a series of "y"characters.Baud is set for 4800 and am using latest example and libraries.kpc
thinwing
Postby adafruit_support_bill » Mon Apr 23, 2012 7:27 pm
That sounds very much like a baud-rate mismatch. Try different rates in the serial monitor.
Postby thinwing » Mon Apr 23, 2012 11:51 pm
Wouldnt that require a change in baud rate statement in the schetch??..kpc
thinwing
Postby adafruit_support_bill » Tue Apr 24, 2012 4:49 am
Only change one side at a time. It is easier to change it in the serial monitor and see if the output improves.
Postby thinwing » Tue Apr 24, 2012 11:36 am
Oh oh wasnt able to bring up schetch and thus serial monitor...arduino ide can no longer connect with arduino uno....it would connect on com 13,when i plugged in computer said unrecognized device and com 13 no longer comes up as a option under tools,serial ports in arduino 1......now its double help...is this dreaded arduino uno dead board I am hearing about?thanks in advance..kpc
thinwing
Postby adafruit_support_bill » Tue Apr 24, 2012 12:51 pm
First I'd try to un-install & re-install the driver. If that doesn't help, you can try the procedure here: http://arduino.cc/en/Hacking/DFUProgramming8U2
Postby thinwing » Tue Apr 24, 2012 1:19 pm
Device manager isnt seeing anything there to right click on.Not sure how to uninstall and install the driver in the arduino folder that windows xp cant see .help..kpc
thinwing
Postby adafruit_support_bill » Tue Apr 24, 2012 1:33 pm
Did you check under "other devices" or "unknown devices". I've seen them show up in odd places.
If it doesn't show up anywhere, the 8U2 reset it the next thing to try.
Postby thinwing » Tue Apr 24, 2012 2:26 pm
8u reset acomplished,driver uninstall,install acomplished,device manager found arduino uno on com 15 with comment device cant start code 10.driver is 5.1.2600.0 dated 11/15/2007....that seems old ...is that the most recent driver and by the way was working fine before..kpc
thinwing
Postby adafruit_support_bill » Tue Apr 24, 2012 3:52 pm
I just checked on my Win-7 system and it has the same exact driver version & date.
cant start code 10
That means that the driver is unable to initiate communications with the device. Doesn't look good for your UNO.
Postby thinwing » Tue Apr 24, 2012 4:07 pm
Doesnt look good huh?well i think I purchased from you a month and half or so,so I would like to send it back to you under warrenty claim ,I think this is a hardware issue ,unless you have any more suggustions,...sinc kp couch
thinwing
Postby adafruit » Tue Apr 24, 2012 4:55 pm
thinwing wrote:Doesnt look good huh?well i think I purchased from you a month and half or so,so I would like to send it back to you under warrenty claim ,I think this is a hardware issue ,unless you have any more suggustions,...sinc kp couch
hiya, please email support@adafruit.com and we'll see what we can do for you!
thanks,
adafruit support
Postby thinwing » Tue Apr 24, 2012 5:30 pm
Thankyou for the quick reply.Will contact support as you suggust,regards kp couch
thinwing
Next
Return to Clocks
Users browsing this forum: No registered users and 1 guest
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
