Reprogramming the Ice Tube Clock?
Tick Tock Clock Kits
Postby crites » Mon Apr 30, 2012 11:19 am
Can anyone tell me if I can use the Serial SpokePOV Dongle (DASA AVR Programmer) to reprogram my Ice Tube Clock? I hope so as I sit here looking at my SpokePOV Dongle and Ice Tube with the GPS soldered on.
Also, I notice the Donge has a 10-way connector and the Ice Tube only has a six way.
Thanks.
-Crites
crites
Re: Reprogramming the Ice Tube Clock?
Postby adafruit_support_bill » Mon Apr 30, 2012 12:18 pm
It might work if you make a 10-pin to 6-pin adapter cable. But it would be slow.
This page shows the pinouts: http://www.evilmadscientist.com/article.php/avrtargetboards
Postby crites » Mon Apr 30, 2012 1:29 pm
Slow as in tedious to wire up, or slow as in it will take awhile to actually program the micro on the Ice Tube clock?
It looks like the pin-out diagrams of the 6 and 10-way connectors is exactly what I am looking for. :D
Since I'm only doing this once I'll just wire up a few jumper wires to get the appropriate signals from the 10-way on the serial programmer to the 6-way pins on the Ice Tube clock. While programming I'll keep the jostling to a minimum! :)
crites
Postby adafruit_support_bill » Mon Apr 30, 2012 2:44 pm
Slow as in programming. DASA programmers don't work well with many of the USB/serial adapters. But if you have a setup that worked with the SpokePOV, it should be alright.
Postby crites » Mon Apr 30, 2012 6:37 pm
I haven't used the DASA programmer for anything yet, I bought it thinking I could get away with only spending $7.50 to reprogram my Ice Tube clock to support a GPS time base.
Do you think I should just spend the $22 and buy the USBtinyISP AVR Programmer Kit (USB SpokePOV Dongle) - v2.0?
If I give it a try with the DASA and only get it half programmed will the boot loader still be intact such that I could reprogram it with a USBtinyISP if required?
crites
Postby crites » Mon Apr 30, 2012 9:20 pm
Lined up the signal names between the 6 and 10-way connectors, plugged the RS-323 cable into COM1 on my confuzer, ran avrdude, and everything worked great! OK, maybe I had to mess around with it a little bit, but I didn't cuss once. Programmed in about 10 seconds with COM1 set to 4800 buad.
I change the minutes on my clock to some wrong value and it jumps right back to the correct time..... like it's possessed! :D Must be the flashing LED on the GPS means it's locked. I was impressed after hooking it up in my basement it even sync'd on the right time.
crites
Return to Clocks
Users browsing this forum: No registered users and 3 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
