I am using a chronodot and a LoL Shield, and using the associated Charlieplex library and a host of different RTC libraries.
With ANY RTC example sketch, when I #include the Charllieplex library and add the required "LedSign::Init();" command to the setup(), the sketch crashes. When I '//' out the LedSign::Init(); command, the sketches all proceed properly.
The below attached code is not mine, it was written by Eric Ayars. I amusing it as it is the simplest way to show the problem I am having....
- Code: Select all
// send what's going on to the serial monitor.
// Start with the year
Serial.print("2");
if (Century) { // Won't need this for 89 years.
Serial.print("1");
} else {
Serial.print("0");
Serial.print(Clock.getYear(), DEC);
Serial.print(' ');
// then the month
Serial.print(Clock.getMonth(Century), DEC);
Serial.print(' ');
// then the date
Serial.print(Clock.getDate(), DEC);
Serial.print(' ');
// and the day of the week
Serial.print(Clock.getDoW(), DEC);
Serial.print(' ');
// Finally the hour, minute, and second
Serial.print(Clock.getHour(h12, PM), DEC);
Serial.print(' ');
Serial.print(Clock.getMinute(), DEC);
Serial.print(' ');
Serial.print(Clock.getSecond(), DEC);
// Add AM/PM indicator
if (h12) {
if (PM) {
Serial.print(" PM ");
} else {
Serial.print(" AM ");
} else {
Serial.print(" 24h ");
// Display the temperature
Serial.print("T=");
Serial.print(Clock.getTemperature(), 2);
// Tell whether the time is (likely to be) valid
if (Clock.oscillatorCheck()) {
Serial.print(" O+");
} else {
Serial.print(" O-");
// Indicate whether an alarm went off
if (Clock.checkIfAlarm(1)) {
Serial.print(" A1!");
if (Clock.checkIfAlarm(2)) {
Serial.print(" A2!");
// New line on display
Serial.print('\n');
// Display Alarm 1 information
Serial.print("Alarm 1: ");
Clock.getA1Time(ADay, AHour, AMinute, ASecond, ABits, ADy, A12h, Apm);
Serial.print(ADay, DEC);
if (ADy) {
Serial.print(" DoW");
} else {
Serial.print(" Date");
Serial.print(' ');
Serial.print(AHour, DEC);
Serial.print(' ');
Serial.print(AMinute, DEC);
Serial.print(' ');
Serial.print(ASecond, DEC);
Serial.print(' ');
if (A12h) {
if (Apm) {
Serial.print('pm ');
} else {
Serial.print('am ');
if (Clock.checkAlarmEnabled(1)) {
Serial.print("enabled");
Serial.print('\n');
// Display Alarm 2 information
Serial.print("Alarm 2: ");
Clock.getA2Time(ADay, AHour, AMinute, ABits, ADy, A12h, Apm);
if (ADy) {
} else {
Serial.print(' ');
Serial.print(' ');
Serial.print(' ');
if (A12h) {
if (Apm) {
Serial.print('pm');
} else {
Serial.print('am');
if (Clock.checkAlarmEnabled(2)) {
/* display alarm bits
Serial.print('\n');
Serial.print('Alarm bits: ');
Serial.print(ABits, DEC);
Serial.print('\n');
Serial.print('\n');
delay(1000);
// Display the time once more as a test of the getTime() function
Clock.getTime(year, month, date, DoW, hour, minute, second);
Serial.print(year, DEC);
Serial.print(month, DEC);
Serial.print(date, DEC);
Serial.print(DoW, DEC);
Serial.print(hour, DEC);
Serial.print(minute, DEC);
Serial.println(second, DEC);
