Have built kit thru completion and ALL works as advertised with a minor exception as per the topic title.
So far what I did was to confirm that:
a. battery voltage is sound (it is; measured in the range 2.9-3.0 V while inserted)
b. processor clock is running (it is as per oscilloscope)
c. voltage of "batt sense" pin is as designed (it is; approx 1.2 V on external power; approx 0.7 V on battery).
The description is straightforward: when powering the clock back onto the 9 V source, the time displayed back starts off exactly from the time it was when the external power was removed! In other words, time "was not kept" while under battery power.
It could be either a hardware (faulty/marginal processor IC) or a software problem (untriggerred interrupt?). Unsure as yet.
Would appreciate any instructions and hints as to how I should proceed from here in order to troubleshoot my clock, which otherwise is superb.
Thanks in advance for attention.
