Ice Tube Clock Boost Issues
For RTC breakouts, etc., use the Other Products from Adafruit forum
pircapadi
Post by pircapadi »
I have started assembling my Ice Tube Clock but I am not getting the mentioned boost voltage at the second measuring step.
I am using a 12VDC 2.5A plug pack and the board beeps when I plug it in.
Some measures I took:
7805 pin 1 11.76V
7805 pin 3 4.93V
IC1 pin 12 0.56V
IC1 pin 7 4.65V
Q2 G 0.56V
Q2 S 0V (continuity to GND)
Q2 output (D) 11.8V
Pictures of the board:
Any suggestions?
Re: Ice Tube Clock Boost Issues
Check the battery on your meter. Your 7805 output looks just a little low.
What do you read at the striped end of D3?
How about pin 13 of the processor?
pircapadi
Post by pircapadi »
I replaced the battery and still got the same reading on the 7805 (suspect I need to invest in a better meter).
The striped end of D3 measures 55.5V and IC1 pin 13 measures 1.2V
pircapadi
Post by pircapadi »
Just re-read the instructions and I was measuring at the wrong place. All is good now. Thanks for the help.
Excellent! Looks like a good build so far.
Return to “Clock Kits (discontinued)”
