Some Newbie pre-purchase questions for the Ice Tube Clock
by chiragpatnaik on Thu Jul 12, 2012 9:42 am
Folks,
I am fascinated by the Ice Tube clock and eagerly want to try it out. But, the catch is that I have not wielded a soldering iron in a long long time (almost 20 years). The last time was in school in the electronics lab.
So the question to you guys is. How difficult it it to put it together. I understand high voltages are risky and am sufficiently careful about it.
Any other kits I should try out before I get on to this one (I intend to order 2-3 kits together) Someone will carry it back from the US to India.
So I am looking for recommendations for other advanced kits to try out.
Chirag
chiragpatnaik
Re: Some Newbie pre-purchase questions for the Ice Tube Clock
by adafruit_support_bill on Thu Jul 12, 2012 9:52 am
You might want to practice a few joints on a piece of strip-board with some scrap wire first. MintyBoost and MiniPOV are good starter projects too.
All of the clock kits are great. The Monochron is relatively easy. Both the BulbDial and the Ice Tube are a good challenge. If you take the tutorials step by step and check your work against the photos you should be fine. If you run into problems, there is always help here on the forums. :D
by chiragpatnaik on Thu Jul 12, 2012 10:01 am
adafruit_support wrote:If you run into problems, there is always help here on the forums. :D
Super. Any idea on longevity of the Tube? If it is finite? Can I buy a couple and store them for a few years?
chiragpatnaik
by adafruit_support_bill on Thu Jul 12, 2012 10:10 am
Tube life depends partly on how bright you run them. These should be good for 100,000 hours or so.
We do sell replacement tubes in the store.
by wbp on Thu Aug 30, 2012 8:35 pm
Chirag,
If you need them built for you I can help.
William
wbp
by chiragpatnaik on Sun Sep 02, 2012 4:40 am
I didn't get you?!?
I am going to start on this, next weekend. I haven't even done an inventory on the parts yet.
I finished the monochron. Not too happy with the lines in it. Will have to fix that first.
Chirag
chiragpatnaik
by SweetOra on Thu Sep 06, 2012 8:24 am
Thanks for the recommendations, now it's clear!
SweetOra
by Agent_24 on Sun Sep 09, 2012 3:41 pm
There are no 0402 SMDs and no huge ground planes to soak up heat etc, so none of these projects present a huge challenge if you know how to solder properly and have fairly good equipment. If you forget, practice first as already suggested.
You may like to check out this video: http://www.youtube.com/watch?v=I_NU2ruzyc4 (so far the best I've found on Youtube. You have to watch out because some of the videos there are just plain wrong!)
Agent_24
