Monochron Temperature Sensor
Re: Monochron Temperature Sensor
by adafruit_support_bill on Mon Jul 30, 2012 7:04 pm
Looks like it is not recognizing your FTDI cable. Are you sure you have the right serial device selected in the tools menu?
by edc1591 on Mon Jul 30, 2012 7:06 pm
Yup, 100% sure.
edc1591
by adafruit_support_bill on Mon Jul 30, 2012 7:28 pm
Try disconnecting and re-connecting the USB end. The FTDI cable should be recognized by your computer regardless of whether anything is connected to the serial end.
by edc1591 on Mon Jul 30, 2012 7:31 pm
Still getting the same error. I tried a different USB port too.
edc1591
by adafruit_support_bill on Mon Jul 30, 2012 7:46 pm
Can you go back to the last configuration that worked? (prior to the processor swap)
by edc1591 on Mon Jul 30, 2012 8:14 pm
Yep, everything works fine when I put the processors back.
edc1591
by edc1591 on Mon Jul 30, 2012 10:25 pm
OK, I tried using the monochron's processor on the Arduino PCB and it doesn't work either (neither pin 15 or any others). So I guess the problem is the processor. Is it possible I was sent a defective one?
edc1591
by adafruit_support_bill on Tue Jul 31, 2012 5:38 am
Given that the display and other functions work, I don't think it is a bad processor. Looking closer at the design files, I see that the Monochron's processor clock is configured differently than the Arduino's. That explains why a direct swap doesn't work.
by edc1591 on Tue Jul 31, 2012 8:36 am
So, if the processor is fine and the sensor works on the Arduino, it sounds, to me, like it's a software difference between the Arduino and the monochron that is causing this not to work. Does that sound right? Is that possible?
edc1591
by adafruit_support_bill on Tue Jul 31, 2012 8:45 am
I suspect it may be the clock difference. The DHT library uses a 'bit-banged' protocol and the timing will be different with the different clock rate.
by edc1591 on Tue Jul 31, 2012 8:46 am
Would it be possible to modify the DHT library to work with the monochron? Could you possibly point me in the right direction?
edc1591
by adafruit_support_bill on Tue Jul 31, 2012 10:05 am
Looking at the code, all the timing is done with millis(), delay() and delaymicrosecond(). These should work as long as the correct clock frequency is specified in the boards.txt file for the Monochron.
The other thing to check is the pin mappings in pins_arduino.c. Make sure that pin 24 is mapped the same as the Arduino.
by edc1591 on Tue Jul 31, 2012 6:58 pm
So, I don't need to modify the DHT library?
I've attached the monochron directory of my hardware folder. Could you take a quick look to see if I made the correct modifications?
monochron.zip
(215.63 KiB) Downloaded 76 times
edc1591
by adafruit_support_bill on Wed Aug 01, 2012 8:31 am
That is what it looks like. But it is possible there may be other, less obvious timing dependencies in there.
Unfortunately, we can't realistically get involved with debugging modifications to unsupported code. You might try contacting the people that developed the Arduino port of the Monochron.
by edc1591 on Wed Aug 01, 2012 7:00 pm
It looks like the DHT library was the problem. I'm using this library now (http://arduino.cc/playground/Main/DHTLib) and it works!
Thanks so much for all your patience with this :D
edc1591
