Firstly, thanks for building such a great kit - my son and I had a great time building it, and everything went fine until the end point, where we noticed digit 3 is not lighting.
I've spent about 4 hours reading this forum, and trying all the things suggested.
We've gone back and reflowed all the solder numerous times
Checked the continuity to the VFD driver of VFD3 (perfect)
There is voltage on pin 21 of the tube.
Tried shorting another working pin over to pin 21, with no luck.
I actually like that this kit has forced us to troubleshoot and learn more about the circuit.
What should I do next?
Ice Tube Clock - Digit 3 not lighting
- philmonty
- Looks messy, but that is flux
- 2012-08-25 18.02.17.jpg (36.86 KiB) Viewed 2670 times
- Soldering PCB
- 2012-08-25 18.01.59.jpg (44.29 KiB) Viewed 2670 times
- Showing missing digital (3rd from left)
- 2012-08-25 18.01.15.jpg (34.91 KiB) Viewed 2670 times
Re: Ice Tube Clock - Digit 3 not lighting
It looks like you have a 22 pin tube, correct?
Can you get a clearer shot of the tube-board and indicate the pin you have identified as 21?
If you size it to about 800x600 we can see more detail.
- philmonty
Yes, a 22pin tube. I used the document on the download page to figure out 6,7,8 were not connected, so just counted around from there. I don't have a very good digital camera, and this is blurry, but is what I identified as pin 21.
- screwdriver points to pin 21
- 1-2012-08-26 10.39.36.jpg (25.69 KiB) Viewed 2644 times
- philmonty
P.S. Is there any sort of reference that shows the tube pin numbers as per the PCB?
- philmonty
Actually, I just looked further into the Tube document, and it states that pin 19 is the one that drives my missing digit. I just measured the voltage at pin 19 and it is zero, so I assume that's my problem.
I need to head to a conference for 3-4 days, so don't have time to troubleshoot now, but could someone clarify to me exactly connection/pin to troubleshoot to solve my missing digit? Much appreciated.
Phil
Phil
- john444
Hi Phil,
Even a low resolution camera benefits from good lighting.
Try taking the whole thing outside in the sunlight.
Good photos will help to make this much easier.
John
John
- philmonty
Thanks for the reply John, and I did as you asked. Let me know if any more pics are needed.
- 1-2012-08-26 12.04.25.jpg (277.86 KiB) Viewed 2641 times
- 1-2012-08-26 12.04.11.jpg (340.28 KiB) Viewed 2641 times
- 1-2012-08-26 12.04.10.jpg (341.77 KiB) Viewed 2641 times
- philmonty
More pics
- 1-2012-08-26 12.04.35.jpg (295.85 KiB) Viewed 2641 times
- 1-2012-08-26 12.04.30.jpg (165.28 KiB) Viewed 2641 times
Thanks, those pictures are much better.
Does shorting it to an adjacent pin light the digit?I just measured the voltage at pin 19 and it is zero, so I assume that's my problem.
- john444
Phil,
Much better photos! Thanks for going to the extra trouble.
Adafruit support has by far the most experience with such things and usually picks up on issues right away.
The only things I see (in the latest batch of photos),
there appears to be excess solder on the 'tube side' of the pc board.
And, probably not related but there may be a scratch through the trace that runs around the pc board (opposite the tube).
You can remove extra solder using solder-wick or apply extra flux and re-melt.
For the scratch in the pc board trace, carefully scrape the solder-mask to expose bright copper and bridge the gap with solder.
I am not sure which digit you indicated is #3.
Tube pin-19 appears to me to be digit-7, the un-used digit between the minutes & seconds.
Good luck with the trouble-shooting.
John
VFD3 goes back to connector J2 pin-3.
Connector J2 pin-3 goes back to the MAX6921 pin-21.
You can keep checking back until the 30-60-v shows up.
When you find that spot, the problem is between where the v shows up and where it disappears.
From the schematic, Digit 3 (VFD3) is tube pin-16.philmonty wrote:P.S. Is there any sort of reference that shows the tube pin numbers as per the PCB?
John
- philmonty
Hi John
Thanks again for the reply. One thing that confuses me is that the design says the missing digit (7th from right, I think the schematic says it's digit 7) is pin 16 (VFD3), but the last page of the IW-18 tube schematic (http://www.tube-tester.com/sites/nixie/ ... /IV-18.pdf) says it's pin 19.
which one is it? Sort of tough to troubleshoot when you're not exactly sure.
All advice is welcome. Also, exactly where do you see the broken trace? I can't see it.
Are you counting pins from the solder-side or the tube-side of the board? I believe the diagram you linked is looking from the solder-side.
- john444
Hi Phil,
John
john444 wrote:there may be a scratch through the trace that runs around the pc board
I am not at all certain but refer to the photo for the location of the scratches on the trace. Any luck following the voltage to the dead digit?philmonty wrote:exactly where do you see the broken trace? I can't see it
John
- adafruit_support_rick
I'm pretty sure the pin that controls that digit is pin 19 on the tube.
In the picture of the solder-side of the tube board, the two pins at the bottom of the picture, with the visible traces coming from either side, are pins 12 and 13. Numbering is clockwise.
So, you can see these traces in the picture, which check against the schematic:
So, you should be able to check for continuity between header pin 8 and tube pin 19.
You should also have continuity between header pin 8 and pin 17 of the MAX6921 VFD controller.
You don't have voltage at tube pin 19? You should also check for voltage at header pin 8 and MAX6921 pin 17. If none of these places have voltage, then it's a bad MAX chip. Otherwise, it's a bad solder joint between the chip and the tube.
- pin 2 of the 2X10 header connecting to tube-pin 13
pin 4 of the 2X10 header connecting to tube-pin 15
pin 20 of the 2X10 header connecting to tube-pin 12
- philmonty
Thanks for the reply - I ended up finding a bad join on the J2 connector - I knew there was one when I picked up the board with my fingers across the pins, and the digit lit up very dimly
Appreciate all the great assistance - now have a fabulous working clock.
Phil
Phil
