Monochron kit LCD not working
Re: Monochron kit LCD not working
by adafruit_support_bill on Sun Sep 16, 2012 4:06 pm
One pin on the CPU looks a little suspect (bottom left pin on the CPU in the solder-side board view). Touch that up & if it doesn't help, we'll try replacing the display.
by dzjay on Mon Sep 17, 2012 8:05 am
adafruit_support wrote:One pin on the CPU looks a little suspect (bottom left pin on the CPU in the solder-side board view). Touch that up & if it doesn't help, we'll try replacing the display.
OK, I tried that. There's no change.
Well, I'm concerned with wasting your time and resources; it could very well be that I screwed something up with my soldering. In that case, I can just toss the kit, chalk it up to experience, and purchase a new one to try again. :)
-dZ.
dzjay
by adafruit_support_bill on Mon Sep 17, 2012 8:33 am
We've seen a lot rougher looking solder on some of these kits. If you contact support@adafruit.com with a link to this thread we can get you a replacement display.
by dzjay on Mon Sep 17, 2012 5:07 pm
Thank you for all the assistance.
By the way, I verified my wife's original order from 11/2010, and noticed that she only purchased the kit. It appears that your fulfillment team sent the "FTDI friend" part by mistake--or else it used to be part of the kit back then.
If it was an error, I really have no problem in returning the part.
-dZ.
dzjay
by adafruit_support_bill on Mon Sep 17, 2012 6:55 pm
Don't worry about the FTDI friend. Let us know how you make out with the replacement display.
by dzjay on Sun Sep 23, 2012 3:44 pm
adafruit_support wrote:Don't worry about the FTDI friend. Let us know how you make out with the replacement display.
Thank you. I received the replacement display, and right when I started working with it, I realized something: I forgot to order also a replacement male header part :(
I tried to re-use the old one by de-soldering it from the board, but I think I ruined it. I can't get it off, and the solder went through the hold and fused on both sides of the board. I was using a soldering iron and a de-soldering plunger/sucker thingy.
Could I order the male header part by itself? I'm prepared to pay for it, since it was my mistake not to include it in the replacement order.
Thank you,
-dZ.
dzjay
by adafruit_support_bill on Sun Sep 23, 2012 4:39 pm
We do have them in stock here: http://www.adafruit.com/products/392
