Arduino Uno assembled in US now available in the Store @arduino & Adafruit #TeamArduinoCC
Ice tube clock will not set
by Locke on Wed Sep 12, 2012 8:56 pm
Only the middle "set" switch works. The menu and + switch do not work. I re-re-re-re-re soldered all the points for all three switches with no change in the results. A second one worked just long enough for me to almost set the time. It is keeping time I just cant set it.
You can see my board at the link below
http://www.flickr.com/photos/87154453@N04/
Locke
Re: Ice tube clock will not set
by neutron spin on Wed Sep 12, 2012 9:57 pm
A closeup would be better but it looks like the right two switches look a little solder starved. The "mounting tabs" seem to look fine but the "switches" look suspect.
neutron spin
by adafruit_support_bill on Thu Sep 13, 2012 5:36 am
Yes. A larger image showing the center portion of the board with switches would be good.
