DS1307 Clock not Working
by techguy777 on Fri Sep 28, 2012 9:29 pm
Hi.
I am having a problem with my ds1307. It was working fine and then all of a sudden it stopped working correctly. I am running the example code for the rtc library
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
void setup () {
    Serial.begin(57600);
    Wire.begin();
    RTC.begin();
  if (! RTC.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    RTC.adjust(DateTime(__DATE__, __TIME__));
void loop () {
    DateTime now = RTC.now();
    Serial.print(now.year(), DEC);
    Serial.print('/');
    Serial.print(now.month(), DEC);
    Serial.print('/');
    Serial.print(now.day(), DEC);
    Serial.print(' ');
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    Serial.print(now.second(), DEC);
    Serial.println();
    Serial.print(" since midnight 1/1/1970 = ");
    Serial.print(now.unixtime());
    Serial.print("s = ");
    Serial.print(now.unixtime() / 86400L);
    Serial.println("d");
    // calculate a date which is 7 days and 30 seconds into the future
    DateTime future (now.unixtime() + 7 * 86400L + 30);
    Serial.print(" now + 7d + 30s: ");
    Serial.print(future.year(), DEC);
    Serial.print('/');
    Serial.print(future.month(), DEC);
    Serial.print('/');
    Serial.print(future.day(), DEC);
    Serial.print(' ');
    Serial.print(future.hour(), DEC);
    Serial.print(':');
    Serial.print(future.minute(), DEC);
    Serial.print(':');
    Serial.print(future.second(), DEC);
    Serial.println();
    Serial.println();
    delay(3000);
When I'm running the problem I get the following response from the Serial Connection.
2165/165/165 165:165:85
since midnight 1/1/1970 = 1402703185s = 16234d
now + 7d + 30s: 2014/6/20 23:46:55
I have checked all the wiring and soldering connections and they all look good.
Thanks in advance!
techguy777
Re: DS1307 Clock not Working
by adafruit_support_rick on Fri Sep 28, 2012 9:42 pm
Hard to say, but the symptoms sound very much like an intermittent connection. If you post some detailed pictures of the soldering/wiring, we'll have a look at it.
by techguy777 on Fri Sep 28, 2012 11:16 pm
Thanks. Here is a picture of the soldering and wiring. Sorry about the poor quality. It's hard to see in the picture but I connected SDA to Digital Pin 4 and SCL to Digital Pin 5. Thanks!
techguy777
by adafruit_support_bill on Sat Sep 29, 2012 4:56 am
Those photos are much too small to see any detail. Try sizing them to about 800x600
by techguy777 on Sat Sep 29, 2012 12:21 pm
Here are the enlarged photos. I apologize about the poor quality.
techguy777
by adafruit_support_bill on Sat Sep 29, 2012 9:58 pm
More light usually helps. Try near a window - or even outside.
by techguy777 on Sun Sep 30, 2012 2:56 pm
Updated Pics. Thanks!
techguy777
by adafruit_support_bill on Sun Sep 30, 2012 5:25 pm
Still pretty out of focus, but from what I can see the solder doesn't look bad.
If you run the sketch several times, does the time increment appropriately between sketches?
by g.ragib on Fri Oct 26, 2012 10:50 am
I have the same problem when I try running the DS1307 with 3.3V instead of 5V.
I would also check 2 other things:
1. Is the coin cell inserted the right way - positive side up?
2. Is the coin cell providing sufficient voltage?
From reading the spec sheet for the DS1307, it seems that a proper coin cell is absolutely necessary for correct operation of the chip.
g.ragib
by csabee on Sat Feb 23, 2013 5:09 pm
I have a strange problem with a DS1307 chip.
I'm using it with an arduino mega adk r3, wired the sda/scl to digital 20 and 21 pins.
I have started from the adafruit sample code. Managed to adjust the time for 2013/2/23 21:48:58
void loop () {
    Serial.print('/');
    Serial.print('/');
    Serial.print(' ');
    Serial.print(':');
    Serial.print(':');
    Serial.println();
    Serial.print(" since 1970 = ");
    delay(3000);
And now I have a problem with the output:
2013/2/23 21:48:58
 since 1970 = 1361656138s = 15759d
2013/2/23 21:48:58
2013/2/23 21:48:58
2013/2/23 21:48:58
2013/2/23 21:48:58
2013/2/23 21:48:58
So the problem is that the DS1307 won't tick, it just stores the adjusted time.
Can you help me, what could be the problem?
Thank you!
csabee
by adafruit_support_rick on Sun Feb 24, 2013 11:06 am
Is this an Adafruit DS1307 breakout board or a bare chip?
by csabee on Tue Feb 26, 2013 6:42 am
No, this one is from ebay, but it has a similar breakout.
csabee
by adafruit_support_rick on Tue Feb 26, 2013 11:13 am
I'm sorry, but you'll have to contact the seller or manufacturer for technical support.
by ockeydockey on Tue May 13, 2014 8:41 pm
I too am having this problem. I have the breakout board from Adafruit for the DS1307. After setting the time with a Raspberry Pi I use it with a Trinket 5v. It keeps perfect time for a good long while, and then stops incrementing. My code recalculate's the display every time it gets a reading, and it keeps repeating the same time. When I hook it back up to the Raspberry Pi (before setting the time again), it starts incrementing again from the time that it was stuck on.
ockeydockey
by adafruit_support_rick on Wed May 14, 2014 6:42 am
Have you tried a fresh backup battery?
Please post clear, detailed pictures of both sides of the board, showing your soldering.
