Monochron build getting 7 Volts for Volage Check
by hs2425 on Mon Dec 03, 2012 12:06 pm
Any ideas, why I am measuring 7V when doing the monochron clock build. I double and triple checked my resistors. After installing IC2 and doing the voltage as shown in the steps, I am seeing 7V not 5V. Any ideas? Could I have a defective IC2? Has anyone run into this issue?
hs2425
Re: Monochron build getting 7 Volts for Volage Check
by adafruit_support_bill on Mon Dec 03, 2012 12:09 pm
Post photos of the front and back of the board and we'll check over your work so far.
One common cause of higher than expected voltage readings is a low battery level in your meter. Make sure you have a fresh battery and check the meter against a known source voltage.
