Ice tube clokc woes
Ice tube clokc woes
by chris doernbrack on Fri Dec 28, 2012 1:26 am
All was going well until I unpackaged the tube and while untwisting the leads one of them broke off. I tried to solder it back on but no luck as it broke so near the glass. Any chance at getting a replacement?
My other issue is that I am not getting the voltage at the regulator anymore. I do get 9.6V on one side of the fuse but the other side is about 1.25V. I have checked my soldering connections, could I have damaged the fuse?
Lastly, I will need to get another replacement part that I broke myself. How do I go about that?
chris doernbrack
Re: Ice tube clokc woes
by adafruit_support_bill on Fri Dec 28, 2012 7:46 am
Hi Chris. Lets start by getting some photos of the front & back of the board so we can check your soldering & assembly so far. Also a complete list of the broken parts. We do have some parts available individually for replacement.
by chris doernbrack on Fri Dec 28, 2012 2:19 pm
http://www.flickr.com/photos/36103403@N00/8319143966
http://www.flickr.com/photos/36103403@N00/8318088401
http://www.flickr.com/photos/36103403@N00/8319146802
http://www.flickr.com/photos/36103403@N00/8319148140
http://www.flickr.com/photos/36103403@N00/8318092331
In terms of the parts I need, you can see the square chip holder is missing on the far right side. I was trying to desolder it and ended up applying to much heat and a couple of pins came out. Until I get the board working I won't know if I need a new tube or not.
Thanks for the help.
Last edited by chris doernbrack on Fri Dec 28, 2012 2:31 pm, edited 2 times in total.
chris doernbrack
by adafruit_support_bill on Fri Dec 28, 2012 2:23 pm
Your images didn't come through. Use the "Upload attachment" tab under the message edit window.
by chris doernbrack on Fri Dec 28, 2012 2:34 pm
chris doernbrack
by chris doernbrack on Fri Dec 28, 2012 4:05 pm
Apparently I had one of the chips in backwards as I wasn't paying attention to the bridge. At this point I will need a PLCC socket as I broke it. I am curious about the tube. when untwisting the leads from the package one broke off at the glass. I put in a short lead hoping it would work but it may not. Would the company send one out as a good gesture given the lead broke as I untwisted them? If not, is there a way to test the tube?
What is the replacemennt cost of the tube?
chris doernbrack
by adafruit_support_bill on Fri Dec 28, 2012 6:00 pm
We can replace the tube for you. You can contact support@adafruit.com with a link to this message.
Unfortunately, w we don't have PLCC sockets for individual sale. The links in the parts list will take you to our sources for these.
Not sure what is up with the fuse. It should break the connection when it overloads, then recover again when it cools down. What resistance do you measure across the leads of the fuse?
by chris doernbrack on Sat Dec 29, 2012 10:56 am
I am sorry, I am not seeing the parts list. Could you email it to doernbrackc@gmail.com. thanks
chris doernbrack
by adafruit_support_bill on Sat Dec 29, 2012 11:36 am
The parts list is part of the tutorial: http://www.ladyada.net/make/icetube/parts.html
