Ice tube clock doesn't display time.
by Alter on Thu Mar 14, 2013 12:57 pm
First off, I see that this is in the FAQ section so please don't refer me there. I'm wondering if anyone has any suggestions. I initially soldered in the 20pf caps rotated 90 degrees the wrong way. I removed them and soldered in new ones. My soldering isn't fantastic but everything else works perfectly so I'm wondering whether I might have irrevocably damaged the PCB while removing the old capacitors. Anyone have any ideas of other things I could try? The elation of making this cool clock has rapidly soured! I'm thinking it's $85 down the drain due to my own screw-up.
Alter
Re: Ice tube clock doesn't display time.
by Alter on Thu Mar 14, 2013 3:33 pm
Looks like cold solder joints. Can't get in to clean them out. Time to order another kit and try again.
Alter
by jarchie on Thu Mar 14, 2013 4:44 pm
Well, that's definitely one solution. But it might be worth trying some less drastic options first.
The second Ice Tub Clock I built failed in exactly the same way and the solution for me was simply to clean the board: viewtopic.php?f=41&t=37846&start=12
If it is a cold solder joint, I've had good luck with solder suckers to remove old solder:
https://www.adafruit.com/products/148
--John <www.jarchie.com/email>
jarchie
by jarchie on Thu Mar 14, 2013 5:01 pm
The Ice Tube Clock boards are quite robust. I would be shocked if your kit were somehow ruined.
jarchie
by Alter on Thu Mar 14, 2013 6:11 pm
Thanks for the advice, I'll certainly give it a try. Regardless, always learning something new and that can't be beat.
Alter
by jarchie on Thu Mar 14, 2013 6:28 pm
Absolutely. I make my worst mistakes when I'm frustrated. If you're like me, letting the project rest for a bit might be worthwhile.
By the way, on my first clock, I desoldered and replaced R3 on five separate occasions. With the through-hole plating, the Adafruit boards are remarkably durable and can handle quite a bit of rework.
jarchie
