Watch crystal in ice tube kit
by Alter on Thu Mar 14, 2013 6:37 pm
Anyone know how durable this thing is? I'm trying to run down issues with my clock not displaying time. All signs seem to point to the crystal and the 20pF capacitors. I've removed solder, resoldered again and again with no luck and I'm wondering if I might have damaged the crystal somehow.
Alter
Re: Watch crystal in ice tube kit
by adafruit_support_bill on Fri Mar 15, 2013 6:04 am
Yes. It is possible to damage the crystal with too much heat. What is the issue? Clock displays but does not update the time?
by Alter on Sat Mar 16, 2013 2:57 pm
Yep, that's it in a nutshell.
Alter
Any recommended sources for getting new crystals?
Alter
by adafruit_support_bill on Sun Mar 17, 2013 6:31 am
If this is one of our kits, we can replace it. But first let's take a look at the rest of the build to make sure there aren't any other contributing factors. If you post clear photos of the front & back of the main board we'll check it over.
by Alter on Sun Mar 17, 2013 9:26 am
Hope these pics are helpful for diagnosis. I think I really botched the soldering of the crystal, there's a blob of solder on top of the board next to each lead.
Alter
by adafruit_support_bill on Sun Mar 17, 2013 10:06 am
With the thin leads on those crystals, that is easy to do. The trick is to heat the solder pad first. When that is hot enough to melt the solder, then let it flow onto the crystal leads.
Contact support with a link to this thread and ask for a replacement crystal. In the mean-time, remove the old one and clean up the excess solder. Some solder-wick might be helpful there. http://www.adafruit.com/products/149
