Ice Tube Clock - Third digit only repeats second digit
For RTC breakouts, etc., use the Other Products from Adafruit forum
SomePinkHeadedPunk
Post by SomePinkHeadedPunk »
Hi, I just finished assembling my Ice Tube Clock, but instead of time displaying like, 10 41 31, the third digit repeats the second and shows 10041 31. It also does the same in any menu, with phrases and such. April displays as Appil, Etc. Help? I don't get it.
Re: Ice Tube Clock - Third digit only repeats second digit
That usually indicates a short between two of the digit control signals - somewhere between the VFD chip and the tube. If you can post some clear photos of the solder-sides of both boards we can try to spot the problem.
SomePinkHeadedPunk
Also... my battery doesn't seem to work in it. I tested the battery. It's good. Any ideas why that isn't working? I'll include some extra photos.
You solder looks reasonably clean & the two signals in question (VFD3 and VFD4) are not on adjacent pins. It is possible that the short is internal to the tube. If you contact [email protected] with a link to this thread we can send you a replacement tube & side board.
As for the battery issue. It is possible that Q3 is reversed. See this thread: http://forums.adafruit.com/viewtopic.php?f=41&t=43209
Return to “Clock Kits (discontinued)”
