The clock is working. When I go into "Menu" and select "Set Time", the periods are under the
time shown. I then try to use the "+" button to set the correct time. The "+" button is not having
any effect. I am going to try and set the date and see if that works.
FYI, I really liked how you had test that could be done during the build process to check the current state.
Joe
ICE Tube Clock: Problems setting time
- adafruit_support_rick
Re: ICE Tube Clock: Problems setting time
Post some photos of your board so we can check the assembly of the switch.
- eeyore124
I went back and looked at it closer. It was simply a bad solder point on one of the legs of the button (the + button), I rushed a bit at the end. I solder it correctly and now it is working fine
