Hey guys, I have a few questions that I am sure are pretty basic.
1 (more of a TinyISP/AVRDude question I guess) - Is it possible to pull the firmware from the clock using a TinyISP kit and AVRDude? I know I can probably download the firmware from the site, but I would like to know for future projects as well.
2 - I downloaded some new firmware I want to try (https://github.com/jsgf/iceclock) and following the tips from the kit's 'mods' page was looking for a .hex file to push to the device. There isn't one as far as my beginner eyes can see. Which of the files do I flash?
Thanks in advance guys, I am still trying to learn the basics of hardware hacking.
Ice Tube Clock: A few programming questions
- solongsidekick
- adafruit_support_rick
Re: Ice Tube Clock: A few programming questions
1) Yes - you can read flash, eeprom, and fuse information
2) looks like you'll haveto make the .hex file. You'll need to install WinAVR on Windows or CrossPack-AVR on Mac.
- solongsidekick
Thanks for the reply! I have some noob follow up questions.
1 - Do you know the command of the top of your head by chance? Googling just gives me some stuff I can't understand .
2 - I have WinAVR installed (Windows machine), I will try launching it and see if I can figure out how to build the .hex.
You can have a look at ladyada's avrdude tutorial.
http://www.ladyada.net/learn/avr/avrdude.html
The read operation looks like the write operation. You just substitute :r: for :w: in the -U option, and the file name is the file to write to.
- phild13
In addition to what rick has pointed to, you can use AVRDudess as a tool to read, write, verify, though you will still need to 'make' the .hex files necessary from the command line.
http://blog.zakkemble.co.uk/avrdudess-a ... r-avrdude/
Jarchis also did a mini tutorial on how to program a chip properly
http://forums.adafruit.com/viewtopic.ph ... 31#p209831
Jarchie also has some info on how to compile in his firmwares readme file:
https://github.com/johngarchie/xmas-ice ... are/README
This information along with the Adafruit info tick pointed to will give you all the tools and information needed to learn how to read, write, verify chips, either in the clock or elsewhere.
- solongsidekick
Thank you Phil! I was having a hard time figuring out how to compile the firmware, you just made my life so much easier! Thank you so much!
- phild13
Your welcome!
