undefined reference in "RTClib.h"
For RTC breakouts, etc., use the Other Products from Adafruit forum
normlane
Post by normlane »
It looks like "secondstime" is declared in the header file but not defined in cpp. Shouldn't that be "secondsTime" anyway? (and unixtime as unixTime for that matter.)
adafruit_support_rick
Re: undefined reference in "RTClib.h"
Post by adafruit_support_rick »
Are you getting an error? That library has been around for ages.
normlane
Post by normlane »
Yeah, here's the error...
saveTime.cpp.o: In function `setup':
C:\arduino/saveTime.ino:36: undefined reference to `DateTime::secondstime() const'
My code...
Serial << newTime.unixtime() << endl;
Serial << newTime.secondstime() << endl;
The unixtime() call works.
Perhaps no one has had a reason to use that function before? I want to initialize a DateTime object with a 32 bit number instead of text. Now that I look more closely I think I should be using unixtime() anyway. For some reason the code seems to expect that but when you initialize with text it chokes on valid unix times with a year less than 2000 and adds an extra 100 years. 1999 will turn into 2099. If you get under the hood this library is a little odd.
Anyway, the missing code for secondstime() is a bug but it's apparently not very critical if no one else has tried to use it.
That is bizarre. I guess you're the first person to try to use that function.
The function itself is pretty simple - it's just unixtime without the constant add:
uint32_t DateTime::secondstime(void) const {
  uint32_t t;
  uint16_t days = date2days(yOff, m, d);
  t = time2long(days, hh, mm, ss);
  return t;
McSummation
Post by McSummation »
I just ran into the same issue. Could you fix the cpp file and reupload it?
normlane
Post by normlane »
Take care. Some of the DateTime init code expects unixtime not secondstime.Check the code in the library.
OK . The library is updated on github. Grab a fresh copy and give it a try
McSummation
I grabbed the update, changed unixtime to secondstime in my sketch and it works properly. Thanks.
Return to “Clock Kits (discontinued)”
