I've been trying to get an alarm once per minute (0 seconds of every minute) working but can't seem to figure out how to do it.
My setup is an Arduino mega 2560 r3 + ethernet shield r3 and chronodot.
The sqm pin is connected to pin2 (interrupt 0) on the arduino and has a 10k pullup resistor.
Instead of connecting to pin2 I also tried it connected to a led but ... nothing, I could however get the 1hz signal working to blink the led.
I've been thru several webpages and few posts here about chronodot alarm but hasn't helped yet, but I think I'm close :s
//set alarm 1
Wire.beginTransmission(CLOCK_ADDRESS);
Wire.write(0x07);
Wire.write(0x0);
Wire.write(0x80);
Wire.write(0x80);
Wire.write(0x80);
Wire.endTransmission();
//set alarm 2
Wire.write (0x0B);
Wire.write (0x80);
Wire.write (0x80);
Wire.write (0x80);
Wire.write(0x0F); //select status registers,
Wire.write(0x0);//reset alarm
Wire.write(0x0E);
Wire.write(0x06);
output:
Initializing ethernet ... success
* Ip address: 192.168.124.223
Initializing SD card ... success
* Card type: SDHC
* Volume type is FAT; 32
* Volume size (bytes): 4062707712
* Volume size (Kbytes): 3967488
* Volume size (Mbytes): 3874
Requesting time from time.nist.gov ... success
* Unix time: 1419717063
* UTC Date/time: 2014-12-27 21:51:3
Chronodot registers:
0 11
1 1010001
2 100001
3 0
4 100111
5 10010
6 10100
7 0
8 10000000
9 10000000
A 10000000
B 10000000
C 10000000
D 10000000
E 110
F 0
2014-12-27 21:51:3
2014-12-27 21:51:4
2014-12-27 21:51:5
2014-12-27 21:51:6
2014-12-27 21:51:7
2014-12-27 21:51:8
2014-12-27 21:51:9
2014-12-27 21:51:10
#include <Wire.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SD.h>
#include <RTClib.h>
#define DEBUG_ETH true
#define DEBUG_SD true
#define DEBUG_CLOCK true
#define PIN_ETHLED 48
#define PIN_SDLED 47
#define PIN_CLOCKLED 49
#define PIN_INTERRUPTPIN2 0
#define PIN_ALARMINTERRUPT PIN_INTERRUPTPIN2
#define CLOCK_ADDRESS 0x68
bool isEthAvailable = false;
bool isSdAvailable = false;
bool isClockAvailable = false;
byte mac[] = { 0xDE, 0xAD, 0xAC, 0xDE, 0xFE, 0xED };
unsigned int udpLocalPort = 55425;
const char *timeServer = "time.nist.gov";
const int NTP_PACKET_SIZE= 48;
byte ntpPacketBuffer[ NTP_PACKET_SIZE];
EthernetUDP Udp;
Sd2Card card;
SdVolume volume;
RTC_DS1307 rtc;
void setup()
Serial.begin(9600);
while (!Serial) {
Wire.begin();
Wire.write(0x0E);
Wire.write(0x4);
pinMode(PIN_ETHLED, OUTPUT);
digitalWrite(PIN_ETHLED, LOW);
pinMode(PIN_SDLED, OUTPUT);
digitalWrite(PIN_SDLED, LOW);
pinMode(PIN_CLOCKLED, OUTPUT);
digitalWrite(PIN_CLOCKLED, LOW);
pinMode(53, OUTPUT);
pinMode(4, OUTPUT);
digitalWrite(4,HIGH);
pinMode(PIN_ALARMINTERRUPT, INPUT);
if (!isEthAvailable) {
initializeEth();
return;
else
Udp.begin(udpLocalPort);
if (!isSdAvailable)
initializeSd();
if (isEthAvailable && !isClockAvailable)
SetClock();
DateTime dt = rtc.now();
Serial.print(dt.year());
Serial.print(F("-"));
Serial.print(dt.month());
Serial.print(dt.day());
Serial.print(F(" "));
Serial.print(dt.hour());
Serial.print(F(":"));
Serial.print(dt.minute());
Serial.println(dt.second());
delay(1000);
void OnAlarm() {
Serial.println("On alarm");
Wire.write(0x0F);
void initializeEth() {
if (DEBUG_ETH)
Serial.print(F("Initializing ethernet ... "));
if (Ethernet.begin(mac) == 0) {
if (DEBUG_ETH)
Serial.println(F("failed"));
return;
if (DEBUG_ETH) {
IPAddress ip = Ethernet.localIP();
Serial.println(F("success"));
Serial.print(F("* Ip address: "));
for (byte thisByte = 0; thisByte < 4; thisByte++) {
if (thisByte < 3) {
Serial.print(ip[thisByte], DEC);
Serial.print(".");
else
Serial.println(ip[thisByte], DEC);
digitalWrite(PIN_ETHLED, HIGH);
isEthAvailable = true;
void initializeSd() {
if (DEBUG_SD)
Serial.print(F("Initializing SD card ... "));
if (!card.init(SPI_HALF_SPEED, 4)) {
if (DEBUG_SD) {
Serial.println(F("* is a card is inserted?"));
Serial.println(F("* Is your wiring correct?"));
Serial.println(F("* did you change the chipSelect pin to match your shield or module?"));
return;
} else if (DEBUG_SD) {
// print the type of card
if (DEBUG_SD) {
Serial.print(F("* Card type: "));
switch (card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println(F("SD1"));
break;
case SD_CARD_TYPE_SD2:
Serial.println(F("SD2"));
break;
case SD_CARD_TYPE_SDHC:
Serial.println(F("SDHC"));
break;
default:
Serial.println(F("Unknown"));
// Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
if (!volume.init(card)) {
if (DEBUG_SD)
Serial.println(F("* Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card"));
return;
if (DEBUG_SD) {
// print the type and size of the first FAT-type volume
uint32_t volumesize;
Serial.print(F("* Volume type is FAT; "));
Serial.println(volume.fatType(), DEC);
volumesize = volume.blocksPerCluster(); // clusters are collections of blocks
volumesize *= volume.clusterCount(); // we'll have a lot of clusters
volumesize *= 512; // SD card blocks are always 512 bytes
Serial.print(F("* Volume size (bytes): "));
Serial.println(volumesize);
Serial.print(F("* Volume size (Kbytes): "));
volumesize /= 1024;
Serial.print(F("* Volume size (Mbytes): "));
volumesize /= 1024;
digitalWrite(PIN_SDLED, HIGH);
isSdAvailable = true;
void SetClock() {
if (DEBUG_CLOCK) {
Serial.print(F("Requesting time from "));
Serial.print(timeServer);
Serial.print(" ... ");
sendNTPpacket(timeServer); // send an NTP packet to a time server
delay(1000);
if (!Udp.parsePacket()) {
if (DEBUG_CLOCK)
return;
if (DEBUG_CLOCK)
Udp.read(ntpPacketBuffer, NTP_PACKET_SIZE);
unsigned long highWord = word(ntpPacketBuffer[40], ntpPacketBuffer[41]);
unsigned long lowWord = word(ntpPacketBuffer[42], ntpPacketBuffer[43]);
// combine the four bytes (two words) into a long integer
// this is NTP time (seconds since Jan 1 1900):
unsigned long secsSince1900 = highWord << 16 | lowWord;
const unsigned long seventyYears = 2208988800UL;
unsigned long unixTime = secsSince1900 - seventyYears;
if (DEBUG_CLOCK) {
Serial.print(F("* Unix time: "));
Serial.println(unixTime, DEC);
DateTime dt = DateTime(unixTime);
if (DEBUG_CLOCK) {
Serial.print(F("* UTC Date/time: "));
rtc.adjust(dt);
//set alarm 1
Wire.write(0x07);
Wire.write(0x0);
Wire.write(0x80);
Wire.write(0x80);
Wire.write(0x80);
//set alarm 2
Wire.write (0x0B);
Wire.write (0x80);
Wire.write (0x80);
Wire.write (0x80);
Wire.write(0x0E); //control register 0E
Wire.write(0x06);
printClockRegisters();
attachInterrupt(PIN_ALARMINTERRUPT, OnAlarm, RISING);
digitalWrite(PIN_CLOCKLED, HIGH);
isClockAvailable = true;
unsigned long sendNTPpacket(const char* address) {
// set all bytes in the buffer to 0
memset(ntpPacketBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
ntpPacketBuffer[0] = 0b11100011; // LI, Version, Mode
ntpPacketBuffer[1] = 0; // Stratum, or type of clock
ntpPacketBuffer[2] = 6; // Polling Interval
ntpPacketBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
ntpPacketBuffer[12] = 49;
ntpPacketBuffer[13] = 0x4E;
ntpPacketBuffer[14] = 49;
ntpPacketBuffer[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
Udp.beginPacket(address, 123); //NTP requests are to port 123
Udp.write(ntpPacketBuffer, NTP_PACKET_SIZE);
Udp.endPacket();
void printClockRegisters() {
Serial.println("Chronodot registers: ");
Wire.write(0x0);
for (int reg = 0x0; reg <= 0x0F;reg++) {
Wire.requestFrom(CLOCK_ADDRESS, 1);
Serial.print(reg, HEX);
Serial.print("\t");
Serial.println(Wire.read(), BIN);
