I did all the test as I went, but now I've found myself in a place where even the beginning tests don't validate. Not sure exactly what happened.
F1 is *HOT*
9V on the 9VDC side, and 1.34V on the other.
IC3 pulls .96V, 0V, 0V
Pictures: https://picturelife.com/fsargent/album/SFCt5aQrcRE1PVq
Ice Clock 5V is 1V - help?
Re: Ice Clock 5V is 1V - help?
What was the last step you completed before discovering the problem?
- fsargent
Soldering on the microcontroller and header for the tube.
By microcontroller, do you mean the Atmega chip, or the square VFD controller chip?Soldering on the microcontroller and header for the tube.
In either case, some close-up photos of the soldering in that region would be helpful.
- phild13
It is kinda hard to see in the photos but I think I see that your Q2 FET is installed backwards. The two pins on Q2 that are shorted together should face to the right towards C6/D3. I would verify the installation of Q2 and if it is backwards, turn it around, it should be Ok.
- fsargent
Phil! thank you so much! That was exactly the problem. I didn't realize that there was a orientation to this chip. Re reading the steps I see how I made the mistake.
THANK YOU! What was junk is now gold. You rock.
- phild13
Your welcome!
