I am getting an error "setTime was not declared in this scope":
NeoPixelClockBJS.ino: In member function 'void ClockPositions::update()':
NeoPixelClockBJS:130: error: 'setTime' was not declared in this scope
NeoPixelClockBJS:132: error: 'SECS_PER_HOUR' was not declared in this scope
NeoPixelClockBJS:132: error: 'adjustTime' was not declared in this scope
NeoPixelClockBJS:137: error: 'second' was not declared in this scope
NeoPixelClockBJS:140: error: 'hour' was not declared in this scope
NeoPixelClockBJS:144: error: 'minute' was not declared in this scope
NeoPixelClockBJS.ino: In function 'void loop()':
NeoPixelClockBJS:311: error: 'setTime' was not declared in this scope
NeoPixelClockBJS:313: error: 'SECS_PER_HOUR' was not declared in this scope
NeoPixelClockBJS:313: error: 'adjustTime' was not declared in this scope
The Sketch is the one posted on Adafruit with only one modification:
- strip.setBrightness(20);
I am also using a different GPS receiver (u-blox PAM-7Q) but it is set to output the $GPRMC message at 4800 baud. I confirmed the GPS is functioning properly with the GPS Basic Echo Test.
Within the code I do not see where the setTime variable is defined so is that the issue and missing code?
NeoPixel Ring Clock compiling error
- logan42
Re: NeoPixel Ring Clock compiling error
can you copy and past the exact code you are using?
- zimbie
//NeoPixel clock with FLORA based on Kevin Alford's NeoPixel ring clock face
//https://github.com/zeroeth/time_loop
//http://www.youtube.com/watch?v=b-mROp-ZKuk
//modified by Becky Stern for Adafruit Industries
#include <Time.h>
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
#include <Wire.h>
Adafruit_GPS GPS(&Serial1);
#define PIN 12
// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
// Set to 'true' if you want to debug and listen to the raw GPS sentences
#define GPSECHO false
// this keeps track of whether we're using the interrupt
// off by default!
boolean usingInterrupt = false;
// From adaFruit NEOPIXEL goggles example: Gamma correction improves appearance of midrange colors
const uint8_t gamma[] = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1,
1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3,
3, 3, 4, 4, 4, 4, 5, 5, 5, 5, 5, 6, 6, 6, 6, 7,
7, 7, 8, 8, 8, 9, 9, 9, 10, 10, 10, 11, 11, 11, 12, 12,
13, 13, 13, 14, 14, 15, 15, 16, 16, 17, 17, 18, 18, 19, 19, 20,
20, 21, 21, 22, 22, 23, 24, 24, 25, 25, 26, 27, 27, 28, 29, 29,
30, 31, 31, 32, 33, 34, 34, 35, 36, 37, 38, 38, 39, 40, 41, 42,
42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57,
58, 59, 60, 61, 62, 63, 64, 65, 66, 68, 69, 70, 71, 72, 73, 75,
76, 77, 78, 80, 81, 82, 84, 85, 86, 88, 89, 90, 92, 93, 94, 96,
97, 99,100,102,103,105,106,108,109,111,112,114,115,117,119,120,
122,124,125,127,129,130,132,134,136,137,139,141,143,145,146,148,
150,152,154,156,158,160,162,164,166,168,170,172,174,176,178,180,
182,184,186,188,191,193,195,197,199,202,204,206,209,211,213,215,
218,220,223,225,227,230,232,235,237,240,242,245,247,250,252,255
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_RGB Pixels are wired for RGB bitstream
// NEO_GRB Pixels are wired for GRB bitstream
// NEO_KHZ400 400 KHz bitstream (e.g. FLORA pixels)
// NEO_KHZ800 800 KHz bitstream (e.g. High Density LED strip)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(36, PIN, NEO_GRB + NEO_KHZ800);
//Your NeoPixel rings may not line up with ours, or each other. |
//Enter which NeoPixel leds are on top LED (0-23 and 0-13). |
#define outerTOP_LED 10
#define innerTOP_LED 5
int outertopLED = outerTOP_LED;
int innertopLED = innerTOP_LED;
float fLat = 0.0;
float fLon = 0.0;
//tequila sunrise color scheme
uint32_t milli_color = strip.Color ( 44, 21, 0); // redest orange
uint32_t second_color = strip.Color ( 44, 30, 0); //slightly yellower
uint32_t hour_color = strip.Color ( 44, 42, 0); //yellow
uint32_t minute_color = strip.Color ( 43, 0, 5); //red
uint32_t off_color = strip.Color ( 0, 0, 0);
//blue, green, & purple color scheme
uint32_t milli_color = strip.Color ( 24, 0, 24); // magenta
uint32_t second_color = strip.Color ( 17, 0, 44); // purple
uint32_t hour_color = strip.Color ( 0, 10, 44); // royal blue
uint32_t minute_color = strip.Color ( 0, 44, 10); // green
// Offset hours from gps time (UTC)
//const int offset = 1; // Central European Time
const int offset = -4; // Eastern Daylight Time (USA)
//const int offset = -5; // Central Daylight Time (USA)
//const int offset = -8; // Pacific Standard Time (USA)
//const int offset = -7; // Pacific Daylight Time (USA)
/* CLOCK */
class ClockPositions
public:
uint8_t milli;
uint8_t currentsecond;
uint8_t currentminute;
uint8_t currenthour;
ClockPositions ();
void update ();
ClockPositions::ClockPositions()
milli = 0;
second = 0;
minute = 30;
hour = 6;
//DateTime(__DATE__, __TIME__);
if (GPS.fix) {
// set the Time to the latest GPS reading
setTime(GPS.hour, GPS.minute, GPS.seconds, GPS.day, GPS.month, GPS.year);
delay(50);
adjustTime(offset * SECS_PER_HOUR);
delay(100);
currentsecond = outertopLED + map ((second() % 60), 0, 60, 0, 23);
if (currentsecond > 24) {currentsecond = currentsecond-24;};
milli = map ((millis() % 1000), 0, 1000, 0, 24);
currenthour = innertopLED + map ((hour() % 12), 0, 12, 24, 35);
if (currenthour > 35) { currenthour = currenthour-12;}
//Serial.print("the hour is: ");
//Serial.println(hour());
currentminute = outertopLED + map (minute() % 60, 0, 60, 0, 23);
if (currentminute > 23) {currentminute = currentminute-24;};
//Serial.print("the minute is: ");
//Serial.println(minute());
/* CLOCK VIEW */
class ClockSegments
public:
ClockPositions &positions;
Adafruit_NeoPixel &strip;
ClockSegments (Adafruit_NeoPixel&, ClockPositions&);
void draw ();
void clear ();
void add_color (uint8_t position, uint32_t color);
uint32_t blend (uint32_t color1, uint32_t color2);
ClockSegments::ClockSegments (Adafruit_NeoPixel& n_strip, ClockPositions& n_positions): strip (n_strip), positions (n_positions)
void ClockSegments::draw()
clear();
add_color (positions.currentminute, minute_color);
//Serial.println(positions.minute);
add_color (positions.currenthour, hour_color );
add_color (positions.currentsecond % 24, second_color);
add_color ((positions.currentsecond+1) % 24, second_color);
//add_color ((positions.second+2) % 24, second_color);
add_color (positions.milli % 24, milli_color);
add_color ((positions.milli+1) % 24, milli_color);
add_color ((positions.milli+2) % 24, milli_color);
strip.show ();
void ClockSegments::add_color (uint8_t position, uint32_t color)
uint32_t blended_color = blend (strip.getPixelColor (position), color);
/* Gamma mapping */
uint8_t r,b,g;
r = (uint8_t)(blended_color >> 16),
g = (uint8_t)(blended_color >> 8),
b = (uint8_t)(blended_color >> 0);
strip.setPixelColor (position, blended_color);
uint32_t ClockSegments::blend (uint32_t color1, uint32_t color2)
uint8_t r1,g1,b1;
uint8_t r2,g2,b2;
uint8_t r3,g3,b3;
r1 = (uint8_t)(color1 >> 16),
g1 = (uint8_t)(color1 >> 8),
b1 = (uint8_t)(color1 >> 0);
r2 = (uint8_t)(color2 >> 16),
g2 = (uint8_t)(color2 >> 8),
b2 = (uint8_t)(color2 >> 0);
return strip.Color (constrain (r1+r2, 0, 255), constrain (g1+g2, 0, 255), constrain (b1+b2, 0, 255));
void ClockSegments::clear ()
for(uint16_t i=0; i<strip.numPixels (); i++) {
strip.setPixelColor (i, off_color);
/* SIMPLE MIXER */
// add rgb and clamp
/* APP */
ClockPositions positions;
ClockSegments segments(strip, positions);
void setup ()
//Brightness adjustment (10 is off, 255 is max)
// connect at 115200 so we can read the GPS fast enough and echo without dropping chars
// also spit it out
Serial.begin(4800);
Serial.println("Adafruit GPS library basic test!");
// 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
GPS.begin(4800);
// uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
//GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
// uncomment this line to turn on only the "minimum recommended" data
//GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
// For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since
// the parser doesn't care about other sentences at this time
// Set the update rate
//GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
// For the parsing code to work nicely and have time to sort thru the data, and
// print it out we don't suggest using anything higher than 1 Hz
// Request updates on antenna status, comment out to keep quiet
//GPS.sendCommand(PGCMD_ANTENNA);
delay(1000);
// Ask for firmware version
//Serial1.println(PMTK_Q_RELEASE);
strip.begin ();
strip.show (); // Initialize all pixels to 'off'
uint32_t gpsTimer = millis();
uint32_t startupTimer = millis();
void loop ()
// read data from the GPS in the 'main loop'
char c = GPS.read();
// if you want to debug, this is a good time to do it!
if (GPSECHO)
//if (c) Serial.print(c);
// if a sentence is received, we can check the checksum, parse it...
if (GPS.newNMEAreceived()) {
// a tricky thing here is if we print the NMEA sentence, or data
// we end up not listening and catching other sentences!
// so be very wary if using OUTPUT_ALLDATA and trytng to print out data
//Serial.println(GPS.lastNMEA()); // this also sets the newNMEAreceived() flag to false
if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
return; // we can fail to parse a sentence in which case we should just wait for another
// if millis() or timer wraps around, we'll just reset it
if (gpsTimer > millis()) gpsTimer = millis();
//if (GPS.fix) {
delay(50);
Serial.print("\nTime: ");
Serial.print(GPS.hour, DEC); Serial.print(':');
Serial.print(GPS.minute, DEC); Serial.print(':');
Serial.print(GPS.seconds, DEC); Serial.print('.');
Serial.println(GPS.milliseconds);
delay(100);
// approximately every 60 seconds or so, update time
if ((millis() - gpsTimer > 60000)) {
gpsTimer = millis(); // reset the timer
if (GPS.fix) {
delay(50);
delay(100);
positions.update ();
segments.draw ();
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint32_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
Last edited by adafruit_support_bill on Mon Mar 16, 2015 8:59 am, edited 1 time in total.
Reason: Please use the '</>' button when posting code. Paste your code between the [code] tags.
- logan42
have you installed the library "Time.h"?
http://playground.arduino.cc/code/time
- zimbie
I did not as I assumed that was one of the standard pre-installed libraries in the IDE. I just installed it and the Sketch compiled without any errors. I'll test with the hardware later as I don't have it with me right now.
- powershift
I am now suffering the same setTime() error as described. I've installed the prjc teensyduinoinstall.exe but still looking at this error. I have the time-master folder in the library path and I can see the time.h and timelib.h file. Any hint on how to verify if the library is in use to eliminate this error?
Thanks,
Leonard
post note: I saw the Time.h only has a very short include statement as:
#include "TimeLib.h"
and go ahead to change the statement in Flora_NeoGeo_Watch from
#include <Time.h>
to
and it passes the compilation. I am curious why it happens this way?
Thanks,
Thanks,
Leonard
#include <Time.h>
to
Thanks,
