Hi , first of all sorry if its in the wrong place, it seems the correct place but i could be wrong.
I'm trying to build a stopwatch, that will do the following
Subject 1 press a button and the arduino start the stop watch.
After a few seconds, minutes on 1 hour tops, the Subject 2 touch a pad.
I need the elapsed time between the start and the touch. An result like 10.321 ( like 10 seconds and 321ms)
From what i read i could use millis() from arduino but it seems to have a 1.024ms precision and that could leak a mistake pehaps, so i come across 2 possibilities.
1 - Use another crystal (heard abour ttl gen being better precise)
2 - Chronodot from adafruit could be useful in this case?
There others possibilities?
millisecond precision stopwatch
- adafruit_support_rick
Re: millisecond precision stopwatch
I *think* the millis() function is actually 1.000ms. I haven't looked lately, but that's what I remember. Anyway, the Arduino clock is not particularly accurate, so you don't want to use millis().
You can use a chronodot. Connect the SQW output to an interrupt pin. Increment your time in the interrupt service routine.
- eestevao
thanks for the answer, but just to confirm. With chronodot i can get millisecond right? and its acurrate? and about the acurracy, its like seconds on a day error rate?
Wait - sorry. I don't know what I was thinking. The chronodot SQW output is on a 1 second interval. You'll have to use millis(). You can keep the Arduino clock synced with the chronodot for more accuracy. The Time library will do that for you.
