jellybeans!
Chat about pick and place machines, reflow ovens, assembly techniques and other SMT tips & trix
jellybeans!
Postby adafruit » Thu Nov 05, 2009 1:20 am
fruity, tasty, colorful! sprinkle them on your PCBs... I'm on the hunt for a jellybean collection
http://www.ladyada.net/wiki/mdcpickandplace/jellybeans
so far ive found some dirt cheep reels. let me know if you have others, ill add 'em
Re: jellybeans!
Postby ktownsend » Thu Nov 05, 2009 5:25 am
I added a few common 0603 parts that I've been using ... though they're slightly more expensive since I tend to stick to 1% resistors for the extra $2-3 per reel that they cost. It might add $0,02 to each board. :-) Might add in some tantalums, etc., once I can go through my reels to get all the Digikey references.
ktownsend
Re: jellybeans!
Postby adafruit » Thu Nov 05, 2009 8:48 am
wow that is so fantastic. its exactly what i put the page up for. its such a waste of time to look for the cheapy jellyreels when everyone just wants a goddamn 10K resistor :)
Re: jellybeans!
Postby freaklabs » Thu Nov 05, 2009 8:19 pm
Added 4.7uF/10V and 10uF/10V 0805 ceramic capacitors. These are actually pretty cutting edge technology because ceramics have only been able to get this high in capacitance w/this form factor for a couple of years. The great thing about them is that they come on standard 8mm reels (for cheap PnP feeders), are non-polarized so there's no possibility of stuffing them the wrong direction, cheap, and small. That's why I got so excited when I found them. A reel will set you back a bit, but if you're looking for small bulk caps that are cheap and easy to mount w/a PnP, then you should check them out.
I should mention that you should be careful about the material of these caps. The Y5V material is cheaper but can be off by as much as 80%. The X5R and X7R material is much more stable over temperature and is usually +/-10 to 20%. I generally steer clear of Y5V.
freaklabs
Re: jellybeans!
Postby adafruit » Thu Nov 05, 2009 9:02 pm
nice! ill put in tantalums later, i like to keep it safe with 100uF's once in a while
Re: jellybeans!
Postby freaklabs » Fri Nov 06, 2009 1:53 am
100 uF...themz some big jellybeans :)
freaklabs
Re: jellybeans!
Postby adafruit » Fri Nov 06, 2009 10:59 am
7805 and LM358 are considered jellybeans! :P
Re: jellybeans!
Postby ai_dude » Sun Dec 13, 2009 3:46 pm
adafruit wrote:fruity, tasty, colorful! sprinkle them on your PCBs... I'm on the hunt for a jellybean collection
My jellybeans include MMBT2222A's, 2N7002's, and some SOD-123 or SMA schottkys.
Cheers,
-Neil.
ai_dude
Re: jellybeans!
Postby adafruit » Sun Dec 13, 2009 10:57 pm
great, put up your favvy part #'s in the wiki! :)
Return to SMT (Surface Mount Tech)
Users browsing this forum: No registered users and 3 guests
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
