Using panel assembly with 7722FV
Chat about pick and place machines, reflow ovens, assembly techniques and other SMT tips & trix
Postby blogger » Fri Mar 18, 2011 10:08 pm
Next week I'm getting a batch of boards that are paneled in a 4x3 matrix, looking something like this:
So I think I will need to do something on the MDC to make it use this matrix info for assembly.
I know the spacing between boards is 1mm for v-cut. There's no "guide" on outside of the boards. Has anyone done this assembly and if so, how difficult was it to setup?
One thing I did notice there's no fiducials so I'm not sure how I'm going to be aligning this board.
blogger
Re: Using panel assembly with 7722FV
Postby adafruit » Sat Mar 19, 2011 3:41 pm
we use steprepeat all the time. its in the PCB parts list. use gerb view software to figure out the precise x/y matrix
its pretty easy to use, just TRACE when you're done to make sure you got it right
w/o fiducials its going to be a little tough you may want to use a via as a fiducial
Postby ktownsend » Mon Mar 21, 2011 7:16 pm
I use step and repeat for this all the time (including about 30 panels this week). You just program the board in once, and then specify how many in each direction and the spacing between boards. But I know you don't use teaching mode so I'm not sure if it works differently? No fiducials is definately going to be a problem, though. If it was me, I'd select a via or the corner or a large square pad and set the fiducials to manual alignment (forget the code number).
ktownsend
Postby blogger » Tue Mar 22, 2011 9:37 am
I still don't understand why the software wants "offset" (on the blue assembly screen - press T to set offset) *and* fiducials for alignment. Surely it should be one or the other? What's the point of offset, I never used it. Anyway, will try steprepeat in a couple days.
blogger
Postby adafruit » Tue Mar 22, 2011 12:02 pm
we use both because the bias point/offset can change from panel to panel and if its off by a bit (and when you tile a lot, the error adds up) it doesnt find the fiducial as nicely (we use a small fiducial window for crowded PCBs
having 2 fiducials and checking them for each board increased our yield and accuracy dramatically!
Return to SMT (Surface Mount Tech)
Users browsing this forum: No registered users and 2 guests
New Products [103]
LEDs[109]
Cables[61]
