table top reflow oven
by wa7iut on Sat Mar 03, 2012 12:25 pm
Looking for recommendatons for a commercial table top reflow oven for prototyping. Anyone try the PUHUI T-962A IC Oven seen on eBay?
wa7iut
Re: table top reflow oven
by wa7iut on Mon Mar 05, 2012 12:44 pm
Wonder what reflow oven adafruit uses? WWROAU?
wa7iut
by adafruit on Mon Mar 05, 2012 4:38 pm
check out the SMT forum posts, this has been discussed many times! great stuff there :)
cheers!
adafruit support
by wmdevices on Wed Feb 27, 2013 11:39 am
I bought a BT300CP from Manncorp and it's been great.
It does get a little stinky in the shop as the ventilation isn't perfect. And you need to keep to the center most 12x8 inches or you will get cold spots.
Except for very sparsely populated boards, the oven keeps up nicely with the PnP machine (7722FV).
wmdevices
by bomirbomir on Thu Sep 05, 2013 6:31 pm
Do not even try PHUI (Chinese junk). Their ovens or IR preheaters is a joke. We had purchase some to modify them for our very low cost clients.
No go. If you want to burn the boards or damage them otherwise get their equipment
Recommended staff: http://www.batchoven.info or the best it is: http://www.X-Reflow306.com
bomirbomir
by jvadillo on Wed Sep 18, 2013 3:28 am
I have just purchased one, and I will try it. In some days I will write my comments here.
And come on, it might be chinese junk, but it is really low cost and maybe is a good starting point for those like me that want to test the solder paste solution before buying a much more expensive oven.
There are some people around telling that the device is not perfect and the temperature is not all the same inside the oven, but it does the work if you place the board in the middle.
Well, let see...
Juanra
jvadillo
by 1chicagodave on Wed Sep 18, 2013 12:14 pm
So does a skillet. 8)
http://youtu.be/U2VA48HIE0I
Please forgive my hyperanthropomorphization.
Every answer reveals new questions.
And, yes... there's always a better way to 'do that'.
1chicagodave
by jvadillo on Wed Sep 18, 2013 10:13 pm
Ok. First tests with the T-962A went simply perfect, from the oven point of view (I placed too much paste!). I soldered two boards to see how the result was, and the soldering was correct, shiny and clean.
By the way, no special fumes or odours came out of the oven. I know that there are some people saying that it stinks like a cow ass, but it was not in my case.
We will see when we start with real solder masks...
Juanra
jvadillo
by peskywinnets on Thu Oct 10, 2013 2:13 pm
jvadillo wrote:By the way, no special fumes or odours came out of the oven. I know that there are some people saying that it stinks like a cow ass, but it was not in my case.
if you live on (or close to) a farm, it may be rather difficult to detect such a smell coming from the reflow oven ...in this scenario, make sure there are no cows near by (or at least make sure they are facing you) ....be sure to shut your windows, blow your nose & then repeat the 'oven sniff test'.
peskywinnets
by bmw330i on Sat Oct 12, 2013 12:14 am
My T-962 did ok for a while then stopped heating. I read about a PID upgrade to it and ended up buying a T-962A with the PID controller from the company. I must say it works great. I have a very expensive Manncorp T200C+ that requires 220v 30A to run. This T-962A requires 220v but works ok off my 110v to 220v step up transformer. So I can use a regular outlet and do my reflow now. So far so good. Just search eBay for T-962A PID and you'll find the company (UK).
-DC
bmw330i
