100 pin TQFP doable?
by imaginerobots on Wed Jul 11, 2012 5:16 pm
Hi Folks,
I'm interested in building a PCB based on the 100 pin TQFP ATmega2560. This is the same micro used on the Arduino Mega. Is the PCB assembly of this chip doable using a toaster oven and hand placement?
imaginerobots
Re: 100 pin TQFP doable?
by mikeselectricstuff on Wed Jul 11, 2012 5:53 pm
Absolutely - the key is a good solder paste print.
Alternativly use a line of paste on each edge, flow, and braid off the excess afterwards.
mikeselectricstuff
by imaginerobots on Wed Jul 11, 2012 6:08 pm
mikeselectricstuff wrote:Absolutely - the key is a good solder paste print.
Thanks. Looking at some web videos looks like it will be easier if I use leaded paste. Will also need to get a magnification lens since I can barely see the pins.
imaginerobots
