looking for EPA and flexprog.exe for zavetech
Chat about pick and place machines, reflow ovens, assembly techniques and other SMT tips & trix
dan.grlx
Post by dan.grlx »
I have a Zevatech 570L, I have manual for flexprog but not the software. So I'm looking for the flexprog utility. I believe the Zavetech 460 and 560 uses the same one.
Also have the EPA manual but not the software. This is used for programming offline. I can probably live with out it.
Anybody have experience with the Zevatech 570L
So far it seems easy to use, but teaching it seems a bit tedious. I really need to get the CAD import to work, which requires the FLEXPROG
Dan
alphatronique
Re: looking for EPA and flexprog.exe for zavetech
Post by alphatronique »
Hi
go in zevatech yahoo group for flexprog
but i not sure that this tool hadel the 570
since the 570 was strange machine (a 560 whit kind of custom/hacked software build by usa branch)
i never hear of EPA ?
Best regard
Marc L.
Alphatronique
sarason
Post by sarason »
My program PCBSynergy will program a 570 Zevatech, it basically replaces Flexprog and runs under modern 32bit Windows environments.
It is located here
http://members.iinet.net.au/~sarason/
As Marc pointed out joining the Yahoo group Zevatech is a good thing as there are many posts of Zevatech Technical support.
The program You are trying to locate is called EPU, and when you find a copy for the 570L could you send me a copy too. The Flexprog program
basically reads in a Text file to generate the Zevatech *.P5A file but without multi-panel support. The EPU program then adds this in within the *.P5A program.
Any other questions, I am happy to answer directly from my email or through the Zevatech Yahoo forum, I only very ocassionally log into this forum
regards sarason.
dan.grlx
Post by dan.grlx »
Thanks Sarason. You're correct it is called EPU (External Programming Unit). I have the manual but not the software. I tried your PCBSynergy. I loaded file into the 570L with no problem, data looks correct. I haven't ran any boards yet as I'm still shopping for an oven.
sarason
Post by sarason »
Does the Zevatech 570L allow the programming of Multiple boards on the panel?
dan.grlx
Post by dan.grlx »
Yes, you can do multiple boards on one panel, it's easy to setup, just enter pitch for x and y and number of rows and columns.
gaz
Post by gaz »
Dan.Grlx wrote:Thanks Sarason. You're correct it is called EPU (External Programming Unit). I have the manual but not the software. I tried your PCBSynergy. I loaded file into the 570L with no problem, data looks correct. I haven't ran any boards yet as I'm still shopping for an oven.
Hi, any way you can post or send me that manual?
dan.grlx
Post by dan.grlx »
Hi Gaz,
Do you have the EPU software?FLEXPROG software.
The manual for EPU is 160 pages, I have hard copy.
IT appears to be almost identical to chapter 4 (OPERATION ) of the PM-570L Instruction Manual.
Almost the same or same software the 570L runs.
I actually copied the 570.exe file from the 570 and tried it in dos box on my XP machine but it gives an error.
Was Flexprog used for Cad data import? I don't have manual for Flexprog.
gaz
Post by gaz »
Yes, I do. Send me some way to contact you privately. Your profile has no contact info.
dan.grlx
Post by dan.grlx »
Private messaging seems broken. Can't send you one either.
you can send to trakmate at gmail
problem is gmail doesn't allow .exe even in zip files, A rename is required.
Dan
Return to “SMT (Surface Mount Tech)”
