Is there a Weller solder station that Adafruit would recommend
Hand tools, soldering irons, scopes, multimeters. Talk about em HERE!
Postby dmh » Sat May 05, 2012 12:22 pm
Is there a Weller solder station that Adafruit would recommend? What solder tip is recommended for thru-hole soldering?
Mike
dmh
Re: Is there a Weller solder station that Adafruit would recommend
Postby franklin97355 » Sat May 05, 2012 3:33 pm
Adafruit_support wrote:It all depends on your budget. I would avoid anything less than 25W. The 30W adjustable iron is a nice step up from the typical entry-level iron. Together with a stand it makes a good basic soldering station. The next step up from that would be a temperature-controlled iron like the Hakko-888. Something like that or a Weller WES-51 should last pretty much forever.
franklin97355
Postby adafruit_support_bill » Sun May 06, 2012 5:19 am
Tip style depends somewhat on personal preference. I use Weller ETA or ETH tips for most of my through-hole work.
Postby dmh » Sun May 06, 2012 10:55 pm
Thanks.
Is there a tip that you would recommend for the Hakko?
dmh
Postby adafruit_support_bill » Mon May 07, 2012 5:10 am
I don't have a Hakko, but the T18-D08 and T18-D16 appear to be comparable to the Weller ETH & ETA tips.
Return to Tools Tools Tools
Users browsing this forum: No registered users and 4 guests
New Products [103]
LEDs[109]
Cables[61]
