Conductive Paint, Pens and the like
Hand tools, soldering irons, scopes, multimeters. Talk about em HERE!
Postby E:pp:ik » Thu Jun 30, 2011 8:00 am
Hi folks! I'm a x0xb0x section dweller but from time to time I break out of there:) I gotta hang out in these other sections more often. Every time I look in another direction there's great info to be found.
I have a situation where I have some old obsolete push buttons I need to restore. It's one of those arrangements where there's a rubber suction cup with a contact plate inside a sealed casing. When pushed it makes the connection to two metallic pins on a set of plates below. This engages the button.
The contact in this suction cup has worn out. At best the connection is intermittent. I'm trying to find a solution to recover the plate in that suction cup to restore its ability to connect and one possibility was painting or scribbling in some sort of conductive material. I suspect it's not a long term solution though. Can anyone enlighten me on what options exist? I haven't really found anything 'obvious'.
E:pp:ik | Metro Electro x0xlog
TB-303 ~ x0x SS01 ~ x0x #330 ~ [WIP] x0xio #133
E:pp:ik
Re: Conductive Pens and the like
Postby BruceF » Thu Jun 30, 2011 12:14 pm
It isn't something you could build up with a bit of solder?
- Bruce
BruceF
Re: Conductive Paint, Pens and the like
Postby E:pp:ik » Thu Jun 30, 2011 12:25 pm
I don't think so since it won't adhere to the surface. It's not like a metal contact that could be tinned.
E:pp:ik
Postby BruceF » Thu Jun 30, 2011 12:29 pm
Could you fit/glue in a piece of copper foil or something? That should be easy enough to find at a craft store.
- Bruce
BruceF
Postby E:pp:ik » Fri Jul 01, 2011 8:09 am
I suppose so, but this is going to be used a lot. It's a got to be a rock solid option so I don't have to open it up again for some time. It can't jog loose under any circumstances. I thought that the least intrusive would be some sort of coating (provided it lasts long enough). This is why I was hoping for some sort of commercial grade conductive ink or paint.
E:pp:ik
Postby adafruit_support_bill » Fri Jul 01, 2011 8:48 am
The adhesive on copper tape for PC boards is pretty tenacious. You might also look at some of the pressure sensitive elastomers such as Zoflex or QTC.
Postby E:pp:ik » Mon Jul 04, 2011 8:40 am
Cool. I'll check those out. I started looking at those conductive epoxys but didn't commit. I'll let you know what I settle on and see if it works.
E:pp:ik
Postby mikeselectricstuff » Tue Jul 05, 2011 5:12 pm
There is a product specifically designed to repair conductive rubber pads on membrane keyboards :
http://www.chemtronics.com/products/pro ... &m=2&id=32
mikeselectricstuff
Postby pstemari » Tue Jul 05, 2011 7:47 pm
Haven't tried the Chemtronics stuff for keypad repair, but the conductive pens are unlikely to work. They lay down a fairly hard paint-like coating that would probably chip off a rubber dome.
--Paul
A wholly owned subsidiary of:
Persephone: DL R+W+B C 7 X L W C++ I++ T+ A E H++ S+ V-- F+ Q P B PA+ PL
Aldebaran: DM Rt H 5 Y L- W+ C+ I++ T++ A+++ E H++ S+ V+ F++ Q+ P B++ PA- PL--
pstemari
Return to Tools Tools Tools
Users browsing this forum: No registered users and 1 guest
New Products [102]
LEDs[109]
Cables[60]
