Is there a Weller solder station that Adafruit would recommend
by dmh on Sat May 05, 2012 1:22 pm
Is there a Weller solder station that Adafruit would recommend? What solder tip is recommended for thru-hole soldering?
Mike
dmh
Re: Is there a Weller solder station that Adafruit would recommend
by franklin97355 on Sat May 05, 2012 4:33 pm
Adafruit_support wrote:It all depends on your budget. I would avoid anything less than 25W. The 30W adjustable iron is a nice step up from the typical entry-level iron. Together with a stand it makes a good basic soldering station. The next step up from that would be a temperature-controlled iron like the Hakko-888. Something like that or a Weller WES-51 should last pretty much forever.
franklin97355
by adafruit_support_bill on Sun May 06, 2012 6:19 am
Tip style depends somewhat on personal preference. I use Weller ETA or ETH tips for most of my through-hole work.
by dmh on Sun May 06, 2012 11:55 pm
Thanks.
Is there a tip that you would recommend for the Hakko?
dmh
by adafruit_support_bill on Mon May 07, 2012 6:10 am
I don't have a Hakko, but the T18-D08 and T18-D16 appear to be comparable to the Weller ETH & ETA tips.
