leaded solder
leaded solder
by davidh on Tue May 22, 2012 1:45 pm
HI,
As far as home electronic projects go, does it matter if I use leaded solder?
David
davidh
Re: leaded solder
by adafruit_support_bill on Tue May 22, 2012 2:07 pm
Not really. If you are not licking your fingers and sniffing the fumes, your lead exposure is minimal. The main aim of the industry move to lead-free is the tons of solder that finds its way into landfills from discarded consumer electronics.
Re: leaded solder
by TBayBoy on Fri May 25, 2012 11:04 am
adafruit_support wrote:If you are not licking your fingers and sniffing the fumes
Those were the only things I had left to look forward to ;)
TBayBoy
Re: leaded solder
by Agent_24 on Sat May 26, 2012 8:43 am
Tin\Lead solder is a better choice. It's easier to work with and creates more reliable joints anyway.
Agent_24
Re: leaded solder
by mikeselectricstuff on Sun May 27, 2012 4:12 am
Another reason to avoid leadfree is that the fumes from the flux in leadfree are typically nastier than leaded.
mikeselectricstuff
Re: leaded solder
by kscharf on Fri Aug 31, 2012 3:08 pm
IIRC lead free solder has a higher melting point than the leaded kind. While lead free parts are designed to handle the higher soldering temperature, some things are safer to install at lower temperatures such as LEDS. I've seen too many LED's destroyed by over heating during soldering.
kscharf
Re: leaded solder
by electronbee on Wed Jan 30, 2013 1:55 am
There are different factors to take into account when soldering leaded or lead-free: alloy, temp, and flux.
Any ways, I found a decent article awhile back that goes over different lead-free alloys, etc etc. There is a bit of corporate spiel in the beginning but the knowledge is really good and the uninitiated will get a firm understanding of the concepts. There are associated papers after the initial article which provide even more info for those who wish to geek out.
http://www.psma.com/ul_files/forums/lea ... _guide.pdf
electronbee
