Adafruit: terminal blocks
by davidh on Sat Aug 04, 2012 12:57 am
Hi,,
Do the wires connected to a two pin terminal block connect to each other at the block?
Cheers
David
davidh
Re: Adafruit: terminal blocks
by adafruit_support_bill on Sat Aug 04, 2012 6:17 am
Are you talking about this terminal block? http://www.adafruit.com/products/724
The two terminals are electrically isolated from one another.
by davidh on Sat Aug 04, 2012 7:00 am
yes. Thanks!
davidh
by davidh on Wed Aug 08, 2012 2:57 pm
I thought they connected two wires together but now I am not sure what they would be used for in a perma board. Would you give me an example of how it would be used on a perma board
Cheers
David
davidh
by adafruit_support_bill on Wed Aug 08, 2012 3:09 pm
You would use it to connect two wires to adjacent traces on the board. For example:
    Power & ground.
    Sensor input wires for a 2-wire sensor.
    Output wires for LEDs, motors or other 2-wire devices.
by davidh on Wed Aug 08, 2012 5:08 pm
I guess then you would screw some wires in at the top of the terminal
davidh
by Wody on Wed Aug 08, 2012 7:38 pm
They are used for example in the motorshield, there's a few pictures of them in use at http://www.ladyada.net/make/mshield/use.html
Wody
by davidh on Wed Aug 08, 2012 10:37 pm
Thanks, for the help :D
davidh
