Mitutoyo 500-196-200
by karhong on Sun Aug 26, 2012 3:50 pm
I have the above caliper. This is pre-zeroed in the factory.
In the closed position after ON/OFF, the ABS reading always indicate 126.43-44mm, ie ~5".
It is an absolute measurement, but I cant figure out where this reading comes from.
Your advice appreciated, rgds.
karhong
Re: Mitutoyo 500-196-200
by adafruit_support_bill on Sun Aug 26, 2012 5:20 pm
If you close the caliper and press the zero button (the yellow one) what does it read?
by karhong on Sun Aug 26, 2012 6:27 pm
Pressing the ZERO/ABS less than 2secs put the caliper in INC mode. It now reads 0.00mm
Pressing the ZERO/ABS more than 2secs put the caliper in non-INC MODE. It reads 126.43mm ( for my caliper).
Moving the thumb wheel to/fro always puts the caliper in 0mm in closed position, thus the caliper is good.
But I don't understand where the 126.43mm comes from in non-INC mode ? Rgds.
karhong
by franklin97355 on Sun Aug 26, 2012 11:13 pm
It looks like the button above the display is the origin button.
franklin97355
by adafruit_support_bill on Mon Aug 27, 2012 6:06 am
Sounds like your origin is off. You should be able to zero the origin by closing the calipers and pressing the "origin" button.
by karhong on Mon Aug 27, 2012 6:21 pm
Done.
Thank you all for teh support. Rgds.
karhong
