A bit of soldering help
by jackcust on Thu Dec 13, 2012 12:41 pm
I need to connect the socket of a keypad to a prototyping shield. I was planning to simply solder a male header to the shield, then connect those points to the correct inputs. But I can't fit hookup wire into the same holes the header goes through.
I haven't been working with PCBs for very long and I imagine there is an easy solution. Perhaps I can form a joint between the hookup wire and the header without the wire passing through the hole? But I'm not sure if that's a good idea.
I should mention - this Arduino+shield is going into a small enclosure, so I can't attach a breadboard or anything. The connections have to be made directly to the shield. And I can't take advantage of that series of 3 connected wells, because the keypad socket has to come in from a certain direction.
jackcust
Re: A bit of soldering help
by adafruit_support_rick on Thu Dec 13, 2012 12:49 pm
jackcust wrote:But I can't fit hookup wire into the same holes the header goes through.
A picture might help. But what sort of hookup wire are you using that it won't fit into a header hole? Sounds like your wire is much too heavy. Most people use 22AWG wire.
by jackcust on Thu Dec 13, 2012 12:59 pm
driverblock wrote:A picture might help. But what sort of hookup wire are you using that it won't fit into a header hole? Sounds like your wire is much too heavy. Most people use 22AWG wire.
Thanks - I have that wire, and it fits through the holes in the shield - but not through a hole that I am also sticking a male header pin through. (I suspect I'm going about this unusually.)
jackcust
by adafruit_support_bill on Thu Dec 13, 2012 1:03 pm
A typical prototyping technique is to pass it through an adjacent hole, then bend it over to bridge with the header pin. Solder in both places for a secure joint.
by jackcust on Thu Dec 13, 2012 1:28 pm
adafruit_support wrote:A typical prototyping technique is to pass it through an adjacent hole, then bend it over to bridge with the header pin. Solder in both places for a secure joint.
Sorry to be annoying, but I'm not exactly sure what you mean...
jackcust
by adafruit_support_rick on Thu Dec 13, 2012 1:56 pm
Thusly:
header pin.jpg (10.55 KiB) Viewed 1494 times
by jackcust on Thu Dec 13, 2012 4:30 pm
Thank you! It seems to have worked well.
jackcust
by adafruit_support_rick on Thu Dec 13, 2012 4:36 pm
Cool :D
Thanks for the opportunity to display my awesome artistic chops! :lol:
cron
