Got in Trouble with Hakko FX-888D
Re: Got in Trouble with Hakko FX-888D
by modeller on Mon Feb 25, 2013 6:44 pm
neslekkim wrote:fake, as fake as the hakko fx888, fx951.. fx951-fakes sells for $50 on aliexpress ;)
I bought the previous hakko termometer, also around $15, seems like it works good enough, uses the same sensors.
I got the Hakko FG-100 today. If it's a fake then I'm really impressed with the ability of the fakers. I don't have a "real" one to compare to but, honestly, it would be hard for me to even guess. I mean there are no flaws at all. The box even has a foil-type label. Maybe it isn't a fake? Maybe the cost in the far East is just very low?
modeller
by neslekkim on Mon Feb 25, 2013 6:48 pm
It pussles me sometimes also.. (like when I bought 50 pcs 74hc595 for total $8.. need to build an testrig for those I guess)
Do you have link for that?, is it measuring F or C?
neslekkim
by modeller on Mon Feb 25, 2013 6:59 pm
neslekkim wrote:It pussles me sometimes also.. (like when I bought 50 pcs 74hc595 for total $8.. need to build an testrig for those I guess)
Yes sir -
http://www.ebay.com/itm/160933470443?ss ... 1497.l2649
C, which is no big deal to me.
modeller
by analoger on Tue Feb 26, 2013 11:39 am
If it's a fake, how can you be sure it's not giving you a fake measurement?
analoger
by modeller on Tue Feb 26, 2013 2:38 pm
analoger wrote:If it's a fake, how can you be sure it's not giving you a fake measurement?
Hahaha - because ... well the reason would be ... um ... uh ...
I'll get back to you. :shock:
modeller
by modeller on Tue Feb 26, 2013 9:54 pm
OK, here's what happened. The Hakko soldering station I bought was NOT a fake, so I'm making a rash assumption that it's calibrated since I just got it. If it had been two years, then no ...
I set up the station and FG-100 to make a measurement. The FG-100 senses room temperature and that was spot-on. I turned on the FX-888 and set it to 300C. I waited a little while and put a small spot of solder on the tip, and touched it to the sensor.
I kid you not, I am not joking, and I was shocked -
The FG-100 read ...
300C
It was not even off by 1 deg at first, then went up to 302C after a bit.
:shock:
modeller
by analoger on Wed Feb 27, 2013 2:26 am
Interesting. :o
analoger
by neslekkim on Thu Feb 28, 2013 3:35 pm
Great, ordered!
$16.88 with shipping is very cheap for this, and if it measures correctly its good enough ;)
I checked the the price for the same model, original here in Norway... $520.. that's crazy..
neslekkim
by modeller on Thu Feb 28, 2013 4:30 pm
neslekkim wrote:Great, ordered!
Cool - I hope yours woks as well.
Couple of other things -
Just because I'm me :D I took a piece of ice out of my freezer and touched it to the FG-100 thermocouple. It read 0 to 1 C. It sure has a pretty wide range.
My 15W Radio Shack iron runs at 360C.
modeller
by jaydekay on Mon Dec 30, 2013 6:33 pm
FACTORY RESET SEQUENCE FOUND!
I did the same thing as the OP. After some searching around I found a Factory Reset Sequence that was provided by a Hakko rep.
Check it out here: https://www.youtube.com/watch?v=ecH4c6NdBuo
Enjoy!
jaydekay
by adafruit_support_mike on Wed Jan 01, 2014 2:36 am
Interesting.. thanks for posting that!
by adafruit on Wed Jan 01, 2014 2:34 pm
Thanks, we added it to the product page
by jaydekay on Wed Jan 01, 2014 5:14 pm
You're very welcome, cheers!
jaydekay
by neslekkim on Wed Jan 22, 2014 8:11 pm
If you have one that is Celcius, this trick changes it to farenheit, but I did it one more time, but pressed ok at the A symbol, and it got back to C..
neslekkim
by Chamie on Fri Apr 18, 2014 6:17 pm
neslekkim wrote:If you have one that is Celcius, this trick changes it to farenheit, but I did it one more time, but pressed ok at the A symbol, and it got back to C..
I bet that means United States and Asian defaults.
Also, F/C can be set in the settings menu:
Chamie
