Hi I just received a new EX330 in the mail.
I put in a new battery although the it does not show a low battery when I first turn on the unit.
Then I proceed to plug in the probes (black goes to the middle, and red goes to the right one).
I turn the dial to VDC, leaving it at auto range.
I get my standard AAA and it shows 0.3mV.
Then I try it on 9V square battery and it shows 0.1mV.
Is there something wrong with this meter?
NewExtech EX330
- john444
Re: NewExtech EX330
Hi Nataku,
I'm not trying to speak for Adafruit but, have you plugged in the leads fully?
You also might check the resistance of the leads.
Typically test-leads will indicate 0.1 or 0.2-ohm when shorted together
(on the ohm range). You might try those simple tests.
It will give Support a little more info to go on.
Oh yeah, you are on the DC volts range, right?
Good Luck, John
Good Luck, John
- nataku
Re: NewExtech EX330
Yes, you are correct. The lead was not pushed all the way in.
I did actually do the continuity test and it didn't beep so know the leads/probes either bad or not pushed all the way in.
So I went to grab a different pair from a broken DMM and that one worked. For whatever reason I didn't push it hard enough the first time and I found that the angle connector work best when they are 180 degree apart (making horizontal line) instead of vertical lines. I don't know if I make sense or not but hey it works.
Thanks for the tips John.
- john444
Re: NewExtech EX330
Glad it was helpful.
I don't know how many times I have made that mistake.
It is sure dissapointing when a new 'toy' (oops, I mean tool)
does not work right.
See you around the Forum, John
