Will your IC SN74HC595 - in your product "74HC595 Shift Register - 3 pack PRODUCT ID: 450 "
work with your test product
SMT Test Socket - SOIC-16 Narrow Breakout PRODUCT ID: 1283
and
SMT Breakout PCB for SOIC-16 or TSSOP-16 - 3 Pack! PRODUCT ID: 1207
Will your IC in this Product you sell - Adafruit 16x8 LED Matrix Driver Backpack - HT16K33 Breakout PRODUCT ID: 1427
SMT Test Socket - SOIC-28 Wide Breakout PRODUCT ID: 1281
and
SMT Breakout PCB for SOIC-28 or TSSOP-28 - 3 Pack! PRODUCT ID: 1208
Will you sell the IC Holtek HT16K33 ?
Thank you
Nelson.
Test sockets
- nelhensley
Re: Test sockets
sorry if I posted this in the wrong forum. Support said the engineers would answer my question in the forums. I didn't see a better forum for this type of question. Anyone have an opinion on what forum I should post my question in?
Re: Test sockets
No, those 74HC595 are standard through-hole ICs and will not fit in an SMD IC socket. However, if you want to use them on a breadboard you do not need a socket anyway - the will fit into the breadboard directly.
The same goes for the HT16K33 Breakout board, after soldering the pins to the breakout board PCB, it will plug straight into a breadboard by itself.
