So I decided I would finally use my soldering iron today as I had some electronics to come in I was eager to try. This is my first time.
I plugged in my soldering iron to check that it worked, and it did, so I unplugged it. I put my first resistor ever into my circuitboard and went to plug in my soldering iron again, but it won't turn on. I was looking forward to soldering for the first time.
But it won't turn on no matter what I do? It's the beginners pen soldering iron from the big electronics starter kit.
Please help.
Soldering iron doesn't work at all.
- adafruit_support_bill
Re: Soldering iron doesn't work at all.
So it got hot the first time you plugged it in? Make sure you didn't blow a circuit breaker or trip a GFCI. Plug a lamp or something else into the same socket and make sure it is still live.I plugged in my soldering iron to check that it worked, and it did, so I unplugged it. I put my first resistor ever into my circuitboard and went to plug in my soldering iron again, but it won't turn on.
