USB Microscope 5MP interpolated 220x magnification versus Al
Hand tools, soldering irons, scopes, multimeters. Talk about em HERE!
bgoodr
Post by bgoodr »
I am comparing the capabilities of two USB microscopes through Adafruit:
  1. USB Microscope - 5MP interpolated 220x magnification / 8 LEDs
  2. Aluminum USB Microscope with Precision Stand
The second one is more attractive since it has a precision stand, but the Detailed sections between the two do not allow me to do a fair comparison in terms of its capabilities. For instance, just compare the detailed list on the respective pages below. One has a Image capture line, but the other one does not:
USB Microscope - 5MP interpolated 220x magnification / 8 LEDs has:
Image Sensor: 2.0 megapixel w/high-speed DSP for 5MP interpolation (We compared the output with a non-interpolated 2MP microscope and it does look clearer with the interpolation!)
20x/220x axis micro-lens
Adjustable focal length, from 10mm-50mm
Snapshots via software or pressing the button
Image capture: 2560x2048 (5M Pixel),
               2304x1738 (4M Pixel),
               1600x1200 (2MPixel),
               1280x1024 (1.3MPixel),
               1280x960,
               1024x768,
               800x600,
               640x480,
               352x288,
               320x240,
               160x120.
Video rate of 30f/s at a brightness of 600 lux
Flicker control for 50Hz/60Hz
Video format: AVxI (<-- I added the "x" to by pass a forum bug that sees it as a banned spam word)
Photo format: JPG or BMP
8 white LED light, 40000mLux
20x/200x magnification
USB port powered
TWAIN compatible
Size: 112mm long x 33mm diameter
Aluminum USB Microscope with Precision Stand has:
Image Sensor: (640x480) 0.3 megapixel @ 30 FPS
Up to 300x axis micro-lens
Adjustable focal length, from 5mm to infinite
Resolution 640x480
Video rate of 30f/s
Up to 300x magnification
USB port powered
TWAIN compatible
Does this imply that the only resolution that #2 has a single resolution of 640x480?
adafruit_support_rick
Re: USB Microscope 5MP interpolated 220x magnification versu
Post by adafruit_support_rick »
bgoodr wrote:Does this imply that the only resolution that #2 has a single resolution of 640x480?
Yes, that's true.
Return to “Tools Tools Tools”
