I really want to put the Mini 3-wire Volt Meter into an enclosure like the Panel Current Meter. Is there an option for the 3-wire volt meter to come in a panel mount enclosure?
If not could I purchase 2 of the panel current meters and extract the guts from one and put the volt meter into it's chassis? The tabs sticking out of the side of the current meter make it look like this might be possible...
Thanks in advance for the help!
-CoryF
Enclosure for Mini 3-wire Volt Meter
Re: Enclosure for Mini 3-wire Volt Meter
You can probably find a bezel that will fit around the 3-wire meter at Mouser or Digikey:
http://www.mouser.com/Optoelectronics/D ... el&FS=True
http://www.digikey.com/product-search/e ... 27?k=bezel
You may need to do some digging to find one with the right dimensions though.
