Hakko tips compatible with Atten Iron?
- devsfan1830
Last Feb i bought the Adjustable 50W 110V Soldering Iron PID: 2163 (Blue handle, thumb dial temp adjust). Its made by Atten. I dont have the iron in front of me but i THINK its the AT-ss-50. I see you no longer carry this iron but I'm in need to a fine tip to do some modding on a board that has a TINT surface mount LED and switch. I was just double checking that the T18-S4 Hakko tip is compatible with this iron. If there are tips that are even finer than that that are compatible I would also appreciate a suggestion. The thinner the better as the area i need to reach to desolder and resolder is TIGHT.
- Franklin97355
Re: Hakko tips compatible with Atten Iron?
These are probably the ones you need. At least the model numbers are the same (900M)
