I want to use the velostat for get a sensor value but the sensor value always is higher to 0. I dont push the velostat and the value is higher to 0. How do i know if the velostat is pressed or not?
Flora analog Read with velostat
- adafruit_support_rick
Re: Flora analog Read with velostat
The Velostat will give you a range of values when pressed and not pressed. You will have to calibrate this range. That is, if the velostat reading is above some certain value, then it is not pressed. If the reading is below some certain value, then it is pressed.
