Arduino Mega ADK+Ethernet Shield+CNC Machine!!
by faysalkahen on Thu Jan 24, 2013 5:10 am
Hello fellows.
I'm really having a problem controlling 3D of a CNC machine through arduino ethernet shield. I wrote a simple program to control it without any webserver/webclient coding and shown below and all went smoothly:
[Edit - moderator - please use the 'code' button when submitting code]
int ms2pin1 = 26;
 int enablepin1 = 27;
 int ms1pin1 = 24;
 int sleeppin1 = 25;
 int steppin1 = 22;
 int dirpin1 = 23;
 int dirpin2 = 32;
 int steppin2 = 33;
 int ms2pin2 = 30;
 int enablepin2 = 31;
 int ms1pin2 = 29;
 int sleeppin2 = 28;
 int dirpin3 = 34;
 int steppin3 = 35;
 int ms2pin3 = 39;
 int enablepin3 = 38;
 int ms1pin3 = 36;
 int sleeppin3 = 37;
 pinMode(dirpin1, OUTPUT);
 pinMode(steppin1, OUTPUT);
 pinMode(ms2pin1, OUTPUT);
 pinMode(enablepin1, OUTPUT);
 pinMode(ms1pin1, OUTPUT);
 pinMode(sleeppin1, OUTPUT);
 pinMode(dirpin2, OUTPUT);
 pinMode(steppin2, OUTPUT);
 pinMode(ms2pin2, OUTPUT);
 pinMode(enablepin2, OUTPUT);
 pinMode(ms1pin2, OUTPUT);
 pinMode(sleeppin2, OUTPUT);
  pinMode(dirpin3, OUTPUT);
 pinMode(steppin3, OUTPUT);
 pinMode(ms2pin3, OUTPUT);
 pinMode(enablepin3, OUTPUT);
 pinMode(ms1pin3, OUTPUT);
 pinMode(sleeppin3, OUTPUT);
 digitalWrite(enablepin1, LOW);    // enable easy driver
 digitalWrite(sleeppin1, HIGH);    // easy driver operating
 digitalWrite(ms1pin1, HIGH);    // microstepping disabled
 digitalWrite(ms2pin1, HIGH);    // microstepping disabled
 digitalWrite(enablepin2, LOW);    // enable easy driver
 digitalWrite(sleeppin2, HIGH);    // easy driver operating
 digitalWrite(ms1pin2, HIGH);    // microstepping disabled
 digitalWrite(ms2pin2, HIGH);    // microstepping disabled
  digitalWrite(enablepin3, LOW);    // enable easy driver
 digitalWrite(sleeppin3, HIGH);    // easy driver operating
 digitalWrite(ms1pin3, HIGH);    // microstepping disabled
 digitalWrite(ms2pin3, HIGH);    // microstepping disabled
 void loop ()
   int i;
 digitalWrite(dirpin1,LOW);
   delay(1000);
   Serial.println("Forward");
   for (i=0; i<10000; i++)
   digitalWrite(steppin1, HIGH);
   delayMicroseconds(500);
   digitalWrite(steppin1, LOW);
digitalWrite(dirpin3,LOW);
   delay(1000);
   for (i=0; i<5000; i++)
   digitalWrite(steppin3, HIGH);
   digitalWrite(steppin3, LOW);
 digitalWrite(dirpin2,HIGH);
   delay(1000);
   Serial.println("Down");
   for (i=0; i<15000; i++)
   digitalWrite(steppin2, HIGH);
   digitalWrite(steppin2, LOW);
  digitalWrite(dirpin2,LOW);
   delay(1000);
   Serial.println("Forward & Upp");
   digitalWrite(dirpin1,HIGH);
   delay(1000);
   Serial.println("Reverse");
     digitalWrite(dirpin3,HIGH);
   delay(1000);
   delay(1000);
   delay(1000);
but when it comes to adding webserver coding to this one in order to controll it online..i'm having a big problem... So could someone suggest some help/guidance. Thanks
faysalkahen
